Skirt Board Too Short - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 10:04 AM   #16
Originally Posted by lfvoss View Post
No, you are right. That's how the moulding is designed. This is cliq lock engineered flooring. See the image for a cross section of what the nose looks like.
I wanted to do solid treads, but we just couldn't get the oak treads stained to a reasonable match with the floor; this looks much better.
This looks more of a tripping hazard than what Mouse was saying
mrgins is offline   Reply With Quote
Old 02-23-2011, 10:16 AM   #17
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
You're not gonna like it, but I'm gonna be the bad guy.
Adding a molding to a skirt that's too narrow will always look like (#&P.
Take the skirt off, use it as a template for a new one of proper width and get a true skirt look.....not one that looks like you 1/2 A$$ed it.
When you take all the time and effort to do a task like this, do it right.
Even if it means doing it twice.
Just my 2
BTW
the rest looks great........
tcleve4911 is offline   Reply With Quote
Old 02-23-2011, 09:56 PM   #18
Just my 2
BTW
I agree that this is not something worth doing a shoddy job on, especially with it being so visible.
But, I chose the molding based on matching the thickness of the skirt. So it actually is seemless, for all intents. I haven't painted it yet, but I'm confident right now that it will look like one piece. If not, I agree that it is worth redoing the whole thing.
lfvoss is offline   Reply With Quote
Old 02-24-2011, 09:49 AM   #19
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
....................so you used 2-1/2" colonial casing for a base cap
Now........ how are you going to transition THAT into the rest of your baseboard details.........
Old 02-24-2011, 09:55 AM   #20
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Maybe he could cut off a straight-edge perpendicular to the floor and use some sort of plinth block? It would look kind-of funny with the baseboard cut right into the angled bottom of the skirt/casing.
hyunelan2 is online now   Reply With Quote
Old 02-24-2011, 10:14 AM   #21
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
..........You ever walk into a place and see funky details?
That's all you're gonna see on this...............
....because when you don't step back and redo a mistake ...it takes funky details to make it do anything.....
It's turning into a hodge podge of 'stick this on that' and 'make one of these' butt up against 'something I found'........
Sorry for the rant but people post on these forums to get advice on how to do stuff.
I'm assuming you want advice on how to do it like a professional would do it.
Not how Bubba cobbed his project together.......
Old 02-24-2011, 10:53 AM   #22
hyunelan2's Avatar
Rewards Points: 692
I don't think a single plinth at the bottom of the stairs would make it look "all cobbled together." When it comes to molding, it's as much art as it is science.
Here's an example of the skirt going into a plinth:
How do I install trim around stair treads?
^^^and that's an example of "how a professional would do it," according to who posted it in another thread.
He could also return the casing into the wall and make it look like a single finished edge that the baseboard could butt-up against.
Old 02-24-2011, 07:15 PM   #23
Yeah, this was something I have been concerned about and was thinking along the lines of that plinth block. If I were to redo, can I even get matching colonial baseboard of appropriate height, ie 8.5-10 inches, or would I have to glue together two pieces again?
Old 02-28-2011, 07:01 AM   #24
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Most baseboards are two pieces
1 x 5, 6, or 8 with a base cap installed on top of that.
Sometimes they get tricky.......
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
Need help. Skirt board for stairs? met152 Carpentry 5 02-22-2011 02:31 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 06:57 PM
