Skirt Board Too Short - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 09:39 AM   #1
skirt board too short
Hi all,
I am currently replacing the treads/risers on my stairs and decided to add a skirt board to run along the side. I had to cut it fit over the stairs, ok no problem. Unfortunately, I forgot to account for the width of the risers when determining the size of the skirt board to use and it looks like it is a tiny bit short. I cut the first treads and nosing down to size and fit them in (no glue yet), and as you can tell from the picture the nosing is peaking out over the edge of the skirt.
Is this going to look ok, or should I get my butt back to the store and redo the whole thing?
Thanks.
lfvoss is offline   Reply With Quote
Old 02-22-2011, 09:47 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum!
Looks like a safety hazard to me!
I'd go back to the store.... it sucks, but you don't want anyone tripping.
DM
Old 02-22-2011, 09:53 AM   #3
a piece of cap molding on top of skirt would cover tread and add nice detail
The older I get the better I was
The Following User Says Thank You to tpolk For This Useful Post:
Willie T (02-22-2011)
Old 02-22-2011, 11:31 AM   #4
rditz's Avatar
agreed, maybe as simple as a piece of 1/4 round would make this up and be very simple.
rod
rditz is offline   Reply With Quote
Old 02-22-2011, 11:58 AM   #5
Rewards Points: 5,336
DM
You lost me, Mouse, what's the tripping hazzard?
Ron
Old 02-22-2011, 12:46 PM   #6
the Musigician
I may be blind, but on the right hand side it looks like there's 1/4" rise on the 2" nose!
DM
Old 02-22-2011, 12:52 PM   #7
the Musigician
I'm probably not seeing it right.
DM
Old 02-22-2011, 01:13 PM   #8
If that skirt board isn't attached, or if it's not attached too solidly, just put a shim under it.
pyper is offline   Reply With Quote
Old 02-22-2011, 01:25 PM   #9
DM
I don't think he's put the rest of the tread material on yet. Waiting for a solution for the "proud nose".
There's a molding with a square 1/4" ledge that transitions into a like a 30 degree angle. It's used over doors and windows. Can't remember the name. Maybe shingle molding? That might work, ripped to width.
Ron
Old 02-22-2011, 01:27 PM   #10
Ron
Watercap?
mrgins is offline   Reply With Quote
Old 02-22-2011, 01:28 PM   #11
Good solution, but only if it goes down beyond the top of the tread
Old 02-22-2011, 01:36 PM   #12
Originally Posted by mrgins View Post
Watercap?
Could be, that's what it does.
Ron
Like this.
Old 02-22-2011, 08:04 PM   #13
Thanks guys. I got a couple lengths of 21/32" x 2" casing and just now cut the first one to fit, nailed it in, and puttied up the joint. Waiting for the putty to dry, but it looks better already. I'll be better off with this anyways, as it indeed will look better than just the rounded 90 deg edge.
Old 02-22-2011, 08:10 PM   #14
DM
No, you are right. That's how the moulding is designed. This is cliq lock engineered flooring. See the image for a cross section of what the nose looks like.
I wanted to do solid treads, but we just couldn't get the oak treads stained to a reasonable match with the floor; this looks much better.
Old 02-23-2011, 10:01 AM   #15
Ron
Like this.
Nope, that's something different
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
Need help. Skirt board for stairs? met152 Carpentry 5 02-22-2011 02:31 PM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 07:48 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 06:57 PM
