Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-09-2012, 08:03 PM   #1
skirt board installation
If i just have stringers--how do i make the top and bottom cuts of my skirtboards
CDNSr. is offline   Reply With Quote
Old 01-09-2012, 08:11 PM   #2
Are the two outside stringers held off from the wall with a 2 X 4 behind them for the propper spacing?
Old 01-09-2012, 08:29 PM   #3
Disabled wood vet
titanoman's Avatar
I don't get the question.
Plumb cut on the bottom and a level cut on the top?
Just guessing.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-09-2012, 08:52 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
very true, not enough info given
woodworkbykirk is offline   Reply With Quote
Old 01-09-2012, 09:15 PM   #5
STAFF
BigJim's Avatar
It really depends on the type of stairs you have, does your stairs have an open side or walls on both sides. What will the top of the skirt tie into or die into. Are you trying to cut the bottom or top of the skirt so the top of the skirt is even with your base.
If the walls need to be painted, you can lay the skirt off on the wall to make it easier to cut and figure. Take your framing square and set down on the spacer between the wall and stringer. Make a mark at 12" even if the 1X12 isn't but 11 1/4", at the top of the stairs and again at the bottom of the stairs. Pop a line all the way from the floor through the two marks on the wall up past the last step.
Now you can see where the top of the skirt needs to be cut. If you want the bottom cut to be even with your base mold, just lay a piece of base mold at the bottom on the floor and make a mark where the top of the base intersects with the line you popped for the top for the skirt. Make a mark there. That is where you will want to make a plumb cut so the base will butt into the skirt.
Just a note here, if you plan to install a trim on top of the skirt which looks like the trim on top of you base mold be sure to drop the skirt down to allow for the mold to butt your base and run on up the skirt smoothly, it will look like the molding on to of your base just continues on up the skirt. Or you can just plumb up on your skirt a hair past the last nosing of the bottom tread and butt the base into the skirt there.
If just a straight run with no tie ins or you aren't trying to make the top flush with your base, set the 1X12 (usually) on edge on the treads from top to bottom of the stairs. Have some one hold the 1X so it don't move at all. Plumb the skirt at the top and at the bottom. Make a mark. If there is a 2X4 spacer, like there should be against the wall, be sure to clean any trash out so the 1X will lay all the way to the bottom of the spacer. Once in place check to see how much you will need to cut off the bottom of the bottom of the skirt and make a level mark and cut as described above.
Lay skirt board back onto the spacer if you didn't measure, and see how much you need to cut off the top cut and make a mark and make a level mark there, cut and there ya are. Now if there is a landing or you have an open side all bets are off. I hope this is clear but more than likely it isn't.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 01-09-2012, 09:32 PM   #6
Disabled wood vet
titanoman's Avatar
It is nice of you to spend the time walking the op through this, but you would have to be a pretty good carpenter to keep up, IMO.
But kudos to you.
Old 01-09-2012, 09:49 PM   #7
I do not get to do this job often enough, my guys that work for me do it and there far better them me thank goodness so I cheat and rip a piece of 1/4 louon to 11 1/2" and make a template for the top and bottom cuts.
That way I only can mess up cheap wood when doing trial cuts.
BigJim (01-10-2012)
Old 01-10-2012, 08:38 PM   #8
skirting isnt really a diy trim project. even after trimming close to 40 houses before i started trimming stairs it took me a few sets to get past the head scratching stage to know what to do without thinking . its mostly a matter of making reference lines on the wall with a chalk line first then simply scribing and transferring plumb and level lines
Old 01-10-2012, 08:51 PM   #9
Disabled wood vet
titanoman's Avatar
And don't use red chalk. Paint will never cover it. It's permanent. Use blue.
Old 01-10-2012, 08:56 PM   #10
A handy tool to have for this job, or for cutting any trim for inside or outside corners and crown moulding is
http://www.starrett.com/industries/p...ter-cut-errors
Old 01-10-2012, 11:29 PM   #11
STAFF
BigJim's Avatar
But kudos to you.
Sorry bout that, I never have been good at explaining things very well.
Jim
Old 01-11-2012, 10:58 PM   #12
it also bleeds through primer, orange also works in place of blue and shows up better in dim lit spaces
Old 01-12-2012, 12:33 AM   #13
STAFF
BigJim's Avatar
You don't want to mark on the wall with a ball point pen either.
Jim
Roof to Wall Flashing Installation – Painted Cedar Lap Board Siding Deeppool Roofing 3 12-08-2010 08:36 AM
Trouble with Stair skirt board. Need Advice and help. PIC!! bfan781 Carpentry 10 12-04-2010 01:09 AM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 05:13 PM
can we install cement board(wonder board) sajidshah Flooring 20 09-17-2009 11:40 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
