Size of Garage Door Torsion Spring
Recently, one of my garage door torsion springs was broken. I will ask a professional to replace the torsion springs. Before I call them, I want to know if the torsion springs can be replaced by the little large springs.
The size of my broken torsion spring is 22' length, 2' internal diameter, 0.207' wire diameter. I am thinking to replace two torsion springs with the size of 22' length, 2' internal diameter, 0.218' wire diameter. From the research online, the 0.207' wire diameter spring is rated as 90 lb, and the 0.218' wire diameter spring is rated as 100 lb.
Is there any problem to replace the 0.207' wire diameter spring with the 0.218' wire diameter spring?
Thank you in advance!
