Six Panel Hollow Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-03-2010, 07:41 PM   #1
Six Panel Hollow door
I installed a new hallow 6 panel door and I need some hooks on the back. I bought a 15 inch hook rack 4 hooks on it and I was wondering how to attach it to the door. Should I just glue it with Gorilla Glue?
Any ideas?
coopns is offline   Reply With Quote
Old 05-03-2010, 09:28 PM   #2
You only have 1-1/8" of space so you need a very short one of these.
http://www.johsoncn.com/products/anc...all_anchor.jpg
You need to drill three holes; a center large one and two small holes to accept the spurs that keep the thing from spinning.
Or if the holes are near the door edge you can drill a large hole and put in a wood dowel, and then use regular wood screws to go into the dowel.
Old 05-04-2010, 06:09 AM   #3
kwikfishron's Avatar
Rewards Points: 1,022
How about those “As Seen On TV” peel and stick, reusable, holds up to 20lbs. Super Hooks.
I think I’ve seen them at the hardware store.
If you want to hang the rack you got I’d through bolt with ” carriage bolts with a acorn nut or a nut & washer with a nut cap on the inside.
kwikfishron is offline   Reply With Quote
Old 05-04-2010, 08:56 AM   #4
Thanks for the ideas. Could I use some Liquid Nails or Gorilla Glue?
Old 05-04-2010, 08:58 AM   #5
yes with tape to hold until set and dumpster when you remove hooks
The older I get the better I was
Old 05-04-2010, 11:55 AM   #6
Ask the manuf. for the shear strength of those products, if they'll tell you. I'd go with mechanical fasteners.
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Why can't I cut hollow core interior door with circular saw? Brandnewruins Carpentry 10 07-16-2009 02:56 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
