Sistering Or Shimming Wall Studs For Drywall? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 09:53 PM   #1
Sistering or shimming wall studs for drywall?
I have an older craftsman style bungalow that I am slowly working on, at which point I'm completely remodeling a small kitchen. At this point I ripped out all plaster and lath, which I didn't want to do but had to due to electrical updates, plaster problems etc. and just have exposed wall studs.
Long story short, the studs are in what I would consider good condition; solid, no rot, and seemingly level enough for drywall but there is a little variation (around 3/16" or less)
So should I shim or sister every stud in order to make sure there aren't any problems with the drywall?
How much variation, if any is acceptable in the studs before drywall installation?
Thanks a lot for any info.
GSilversVeneer is offline   Reply With Quote
Old 11-28-2010, 12:41 AM   #2
Registered User
Termite's Avatar
You can drywall a wall with bent studs, studs that don't line up, etc. But the question is, what can you live with? Countertops, shelves, lighting and even pieces of furniture can make variances in the wall show up like crazy. You can add furring strips, cardboard drywall shim strips (sold in big packs at the box stores in the drywall section) or even new studs as necessary. My advice would be to string a couple horizontal stringlines along the walls and see where you need to add material, and do a good job so you have a good finished product.
The Following 2 Users Say Thank You to Termite For This Useful Post:
BigJim (11-28-2010), oh'mike (11-28-2010)
Help - rotten exterior wall support studs Charbl General DIY Discussions 2 11-15-2010 06:27 AM
How to repair rotted joists and studs? Snav Building & Construction 5 02-24-2010 10:35 PM
Steel brackets on wall studs tns1 Carpentry 6 08-25-2009 06:52 PM
Wall studs showing through sheet rock js1971 Remodeling 7 09-11-2008 05:45 AM
Studs showing (bulging) through sheetrock js1971 Building & Construction 2 09-03-2008 06:48 AM
