Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-07-2007, 12:26 PM   #1
Sister Studs in Ceiling (Easy Question)
So I took the drywall out of all the walls and ceiling because I have to re-rock and tile the upstairs bathroom. I have done this once before in the downstairs bathroom and it was successful. In the downstairs bathroom there are joists and it was pretty easy to hang the rock on the celing.
Now, for the upstairs, it is a relatively new addition put on by the former owner of the home - 10 year old addition.
My question is: when I removed the rock from the ceiling I did not find joists - I found 2x4s and they were a little loose but the wood is in good shape. Should I just sister these 2x4s? The roof of the house is on a slight slant which is why I don't think there are joists. Very odd to see 2x4s but I think the concept is the same - just use drywall screws and screw them in at about 6 inches a part, or sister the studs in the ceiling and go 8-10 inches apart. Thoughts?
t3rdeyevisual is offline   Reply With Quote
Old 09-07-2007, 01:18 PM   #2
Mod / ArchiBuilder
Cole's Avatar
How big is the ceiling we are talking about?
2x4 joists has me
Cole is offline   Reply With Quote
Old 09-07-2007, 01:27 PM   #3
8ft x 4ft
Old 09-07-2007, 02:11 PM   #4
Mod / ArchiBuilder
Cole's Avatar
I hope they are spanning the 4' section?
Old 09-07-2007, 02:45 PM   #5
yes, absolutely. They run the length of the room in terms of length and width. It just seemed odd when I took the rock off the ceiling and saw 2x4s. I thought I would be dealing with joists. I am sure it is okay but the studs seemed a little "wobbly" even though the wood seemed relatively new.
Sister studs is what I initially thought of. Thanks in advance for the help
Old 09-07-2007, 04:04 PM   #6
Mod / ArchiBuilder
Cole's Avatar
It wouldnt hurt to sister 2x4's to the joists.
Do you have enough room to make an L with another 2x4 on every joist?
Old 09-07-2007, 07:08 PM   #7
yes, I do. Good idea. This will not make them more "wobbly"?
Old 09-07-2007, 07:51 PM   #8
Mod / ArchiBuilder
Cole's Avatar
It will strengthen them.
Old 09-07-2007, 10:28 PM   #9
well, thank you. I will let you know how it works out.
Old 09-08-2007, 10:16 AM   #10
You could also use blocking to unitize the ceiling. Add 2x4 blocking so the span is cut into thirds. This will eliminate any wobble.
Ron
Old 09-08-2007, 02:07 PM   #11
Ron, I don't quite understand. Can you elaborate a little bit in detail? Is there a picture somewhere that I can look at?
Old 09-08-2007, 02:47 PM   #12
I don't have pictures, sorry. Blocking are short pieces of wood that connect the long 2x4's together. You put three pieces per bay and nail them to the 2x4 joists.
If someone doesn't come along with some graphics, just do a search of framing.
Ron
Old 09-08-2007, 08:47 PM   #13
Mod / ArchiBuilder
Cole's Avatar
Blocking:
Old 09-08-2007, 09:20 PM   #14
Mod / ArchiBuilder
Cole's Avatar
Another style of blocking:
Old 09-08-2007, 09:53 PM   #15
Mod / ArchiBuilder
Cole's Avatar
One more style:
I am done with this post, I hope I helped you out.
More On This Topic
Learn how to paint the bathroom ceiling in this free DIY bathroom repair and home improvement video. Read More »
Learn more about how to apply tape to the ceiling when installing drywall in this free DIY video. Read More »
Learn how to apply tape to the ceiling when installing drywall in this free DIY video. Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
Learn about removing fixtures before painting the bathroom ceiling in this free DIY bathroom repair and home improvement video. Read More »
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
Ceiling Insulation Question cabinetman General Discussion 6 06-04-2007 01:22 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Drywall thickness on ceiling question. Doug Crf Building & Construction 3 08-28-2006 06:47 AM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 12:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
