Sister Or Replace Floor Joists - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2008, 04:46 PM   #16
Hi guys,
Well, I got the first joist out.
thekctermite: You were right. It was not difficult at all and the house is still standing.
Marvin_Gardens: I've got wall jacks under the remaining joists that have the load bearing walls.
I am going to double up the 2x10 non load bearing joists and triple up the 2x10 load bearing joists. I would like to use the bracket in the photo below to mount my joists to my beam. I would be using the double bracket, I just had this laying around. Will a double bracket like the one if the photo be strong enough to support the joists? I also included so other pics.
Thanks again for all the advice.
-B
Sister or Replace Floor Joists-photo0165.jpg   Sister or Replace Floor Joists-photo0168.jpg   Sister or Replace Floor Joists-photo0172.jpg   Sister or Replace Floor Joists-photo0176.jpg   Sister or Replace Floor Joists-photo0174.jpg
brando1118 is offline   Reply With Quote
Old 10-24-2008, 08:40 PM   #17
Joist hangers will do the job. Just make sure you get tico nails because they have more sheer strength that regular nails and are designed for hangers. You can mix those with regular nails.
I suppose there is a thing as having too many nails in a hanger nails but lots is good in my book.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-24-2008, 11:06 PM   #18
Thanks MG,
Didn't even know Tico nails existed. Will do exactly as you stated. Checked out your photo of the beautiful addition you built. Really really cool.
Thanks for the response and the advice!
-B
Old 10-25-2008, 12:21 AM   #19
Registered User
Termite's Avatar
If your joists are sitting on the mudsill (the plate that sits flat on the foundation) then joist hangers are unnecessary. If the joists have a couple inches of bearing then a few nails is all that's needed.
If the joists don't have adequate bearing in some places then joist hangers are appropriate. 10dx1-1/2" tico nails are appropriate for use in the face nails, but the toenails that go in the side of the hanger diagonally through the joist must be full length 10d nails, not tico's.
Old 10-25-2008, 12:25 AM   #20
Thanks thekctermite. Understood!!
-B
Old 10-25-2008, 11:59 PM   #21
Hi guys,
Built and installed my first beam today. Only 10 more to go!
Sister or Replace Floor Joists-photo0196.jpg   Sister or Replace Floor Joists-photo0199.jpg   Sister or Replace Floor Joists-photo0200.jpg
Old 10-26-2008, 12:48 AM   #22
Registered User
Termite's Avatar
Isn't working with wood fun?!?!? Looks like you had pretty good success.
Old 10-26-2008, 01:23 AM   #23
Lansing's Avatar
This is your proof that doing a job right the first time is the way to go...
I can see this one is going well and when its finished you will never have to break your bedroom door down to escape the ...wife ? as it looks from your pictures that you got things going right and level...Good advice here and good luck on the project...Just carefull cutting/nailing near the electic wires...
When the time comes for you to leave this world
the only thing you get to keep is what you gave away...
Lansing
Lansing is offline   Reply With Quote
Old 10-26-2008, 04:41 PM   #24
Chief Nailbender
You likely already completed your project, but I just wanted to point out that that original subfloor was also a membrane, tying the outside garage wall to the house. During re-assembly, bear in mind to adequately fasten that new assembly to the old wall(s).
davitk is offline   Reply With Quote
Old 10-26-2008, 09:11 PM   #25
Registered User
Termite's Avatar
Can you elaborate a litte? The 3/4" floor sheathing somehow ties the garage wall in?
Old 10-26-2008, 09:43 PM   #26
Hi all,
Another newbie question: Do they make triple board joist hangars? I plan on tripling the joists under my floor where the load bearing wall resides. What would be the best way to attach a beam of three 2x10's to the 2x12 beam if there is no such thing as a triple board joist hangar?
Thanks,
-B
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
Carrier 58 PAV-repair vs. replace cczkcb HVAC 8 09-25-2008 01:57 PM
How to replace wood support posts under main beam webjanet Building & Construction 1 09-07-2008 11:15 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
