Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-17-2012, 02:34 PM   #1
simple plywood box
I want to build a simple rectangular platform, about 6 inches high, 2 feet by 3 feet.
It should be able to hold a person up to 200 pounds.
If I made this simply with 4 6" pieces of 3/4 plywood and a 2'x3' sheet of 3/4 plywood on top, glue and wood screws on the joints, would it be sturdy enough, or would it require more support not to collapse under pressure?
wengang1 is offline   Reply With Quote
Old 12-17-2012, 02:37 PM   #2
simple plywood box
Use 2 X 6's to make the box, not plywood 1, 2 x6 in the middle for support and use 3/4" Advantec for the subfloor.
That will be more then strong enough.
Old 12-17-2012, 02:51 PM   #3
simple plywood box
OK Thanks.
To be clear, you're saying one layer of Advantec instead of the plywood, not in addition to, right?
Old 12-17-2012, 04:21 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
simple plywood box
3/4 advantec is floor sheathing.. more than enough strenght.. plywood will work also
woodworkbykirk is offline   Reply With Quote
Old 12-19-2012, 07:59 PM   #5
simple plywood box
Your initial proposal will work without collapsing. It may "feel" spongy though.
One word of caution. One more 6" x 2'-0" spanning the 2 ft direction so as to cut the 3 ft dimension into two 1ft 6 in spaces will prevent the platform from deflecting in the center when under load. Just a suggestion.
Budprine is offline   Reply With Quote
Can I Paint a Plywood Subfloor? LMS1213 Flooring 31 05-06-2012 10:33 AM
Installation options for plywood underlayment? ScooberJake Flooring 0 09-03-2011 12:00 PM
Staples or screws on plywood subfloor? And other questions.... howdihi Flooring 1 08-18-2011 09:50 PM
Roofing plywood advice needed jimd206 Roofing 2 04-25-2011 12:58 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
