Siding A Shed Before Roofing - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 01:47 PM   #1
Rewards Points: 1,062
Question
siding a shed before roofing
i was gonna put the siding on my shed at the upside down V down to where it no longer needs angle cuts before i post roof OSB panes. the reason for it is that this way i get to spare myself of pre-cutting siding planks to fit the length and angle (what a horrible nightmare to have to do) and i just nail them with the slack dangling and then trim it off with a reciprocating saw. after the nightmare of cutting my rafters with birds' mouths to fit, and going back 1000 times until it fit, i am just sick of calibrating length and angle for the rest of my life. i think doing siding at the upside down V like i described above is plain smart but carpentry nazis might disagree saying it's too lazy or slack or whatever.
what does everyone think ?
thanks
Old 01-29-2011, 02:53 PM   #2
KemoSabe
loneframer's Avatar
I think if you consider it a nightmare, DIY may not be for you.
You should be having fun with your project.
The method you describe, if I'm reading it right, is to run your siding above the gable rafters, then use the rafter as a guide to trim off the tops, correct?
You could do that, or tack the piece in place, scribe the top, then remove to cut with a circular saw. Replace the siding using the tack holes to register the piece.
I plan to build a shed this Spring. I also plan to have fun with it and enjoy the time invested in the project.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
amakarevic (01-29-2011)
Old 01-29-2011, 02:59 PM   #3
i am not miserable doing it, i just like to do everything the easiest way possible, i.e. not shed any unnecessary sweat or do it in a way more difficult than necessary.
you are correct, i do plan to use the rafters to guide my saw to make an exact cut of the siding planks so i don't have to do it before i put them on, as i know i will NEVER achieve the perfect cut.
i did the same with sheathing the shed with OSB, i would put the whole OSB on and then trim the overhangs with a sawzall rather than precutting it before posting ... helluva lot easier
Old 01-29-2011, 04:31 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
dude...your scarin me
Tom Struble is offline   Reply With Quote
Old 01-30-2011, 11:01 AM   #5
Framing Contractor
Originally Posted by amakarevic View Post
i am not miserable doing it, i just like to do everything the easiest way possible, i.e. Not shed any unnecessary sweat or do it in a way more difficult than necessary.
You are correct, i do plan to use the rafters to guide my saw to make an exact cut of the siding planks so i don't have to do it before i put them on, as i know i will never achieve the perfect cut.
I did the same with sheathing the shed with osb, i would put the whole osb on and then trim the overhangs with a sawzall rather than precutting it before posting ... helluva lot easier
omg!!!!!!
Joe Carola
Joe Carola is offline   Reply With Quote
Old 01-30-2011, 08:10 PM   #6
Originally Posted by Joe Carola View Post
omg!!!!!!
Joe, you make me laugh out loud !! I hope the sawzall blades were sharp !!
karteberry is offline   Reply With Quote
Shed siding NateHanson Building & Construction 5 10-27-2011 12:16 PM
is roofing felt necessary for a 8x12 shed? jmoney Building & Construction 8 06-16-2010 03:46 PM
Siding for 12x12 shed tcfls2 Building & Construction 11 02-16-2010 03:36 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
