Siding Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 09:09 AM   #1
siding repair
I have replaced 7 sheets of rotten siding. I have used hardi pannels and hardi trims. I have a dillemma whether I should go up and cover the sticking out flashing with 1X6 and ugly seams with 1X4 following the pattern at the bottom ? Is there some air circulation issue (can flashing in the siding be covered ?).
before
http://i282.photobucket.com/albums/k...o/000_0009.jpg
After
http://i282.photobucket.com/albums/k...o/IMG_1621.jpg
http://i282.photobucket.com/albums/k...o/IMG_1622.jpg
http://i282.photobucket.com/albums/k...o/IMG_1623.jpg
http://i282.photobucket.com/albums/k...o/IMG_1624.jpg
Also I was planning to cover those ugly seam with 1X4 on the rest of the siding. The siding is not rotten at the bottom so I can leave it as is, just add 1X4 along the flashing and seams .. Is it a good idea ?
http://i282.photobucket.com/albums/k...o/IMG_1619.jpg
http://i282.photobucket.com/albums/k...o/IMG_1620.jpg
http://i282.photobucket.com/albums/k...o/IMG_1618.jpg
chilangopolaco is offline   Reply With Quote
Old 04-30-2008, 11:58 AM   #2
Registered User
Termite's Avatar
You're asking for trouble by not flashing the 1x4's and horizontal seams as one unit. I don't see any z-bar flashing at the top of the sheet of hardie board.
Never cover flashing with 1x4's or anything else. Incorporate them into the flashed system if you want them.
Siding Repair HELP!! duffers Building & Construction 2 04-28-2008 01:15 PM
siding repair chilangopolaco Carpentry 4 04-22-2008 07:39 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
