Siding Issues - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 01:28 PM   #1
waveblasternutcase
siding issues
cedar siding that is cracking and there are gaps between the overlays. these issues are over the entire house but vary in severity. the worst is the southern facing side and it tends to be worse around windows. i am looking of the best way to repair the siding.....
WBNC is offline   Reply With Quote
Old 08-10-2009, 04:39 AM   #2
Remodeling Contractor
Add spacing wedges below the siding's bottom edge to allow it to breathe. Repair by replacing the boards or using a wood epoxy. For rotted sections use a hardener first.
Old 08-10-2009, 09:17 AM   #3
waveblasternutcase
on some of the smaller gaps i have caulked the overlays. is that incorrect?
Old 08-10-2009, 07:39 PM   #4
no, caulking is fine.
Old 08-10-2009, 09:12 PM   #5
Registered User
Rewards Points: 526
Am I understanding correctly, You caulked the lap joint (horizontally) of one board to the next one below? Be safe, G
Old 08-11-2009, 05:09 AM   #6
That would be a no-no. This is the same area I suggested adding a spacer to allow the wood to breathe better. This will help stop it from cracking more.
Old 08-11-2009, 07:25 PM   #7
Registered User
Rewards Points: 526
That was my polite way of saying - "WHAT, Bob? You said caulk the overlays!!!" No response from the O.P., usually they now ask how to get caulking off. Be safe, G
Old 08-11-2009, 08:01 PM   #8
I was responding to the pictures. Seems one would fix the broken siding edge, not seal off the underside of the lapped joint. But your right, we've got to be careful and expect anything.
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
New siding, paint exsisting siding, or powerwash?? fixiechick General DIY Discussions 5 01-22-2009 11:50 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
