Shower Pan - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 08:43 PM   #1
Monster
shower pan
I am ready for my pre slope for my shower pan. all framed out.
Now the magic question. I am doing my shower pan over a concrete subfloor with drain in place. I will put felt down for my slip sheet.
Do I need wire lath on top of the felt on a concrete subfloor.
I see people putting wire lath over felt for a wood subfloor.
Does the same rule apply for concrete subfloor, and if so how can I secure it to the concrete subfloor?
califmonster is offline   Reply With Quote
Old 07-31-2011, 09:17 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why do you need a "slip sheet" under a shower floor?
Never ever seen that done before. California is a strange place.
XXX
Old 07-31-2011, 09:37 PM   #3
doing mud over concrete you want to mix up some thinset kinda thinner then normal and trowel it on the concrete before you put your mud down. it will help your mud stick to the concrete floor
The Following User Says Thank You to DannyT For This Useful Post:
califmonster (07-31-2011)
Old 07-31-2011, 09:50 PM   #4
Monster
shower pan
it is a shower pan that I am building
Old 07-31-2011, 10:10 PM   #5
Monster
u suk
Old 07-31-2011, 10:18 PM   #6
DIY staff
Rewards Points: 7,174
Building a shower pan with pre-sloped mortar bed, liner and curb.
I build a lot of these pans--I never heard of a 'skip sheet' ,either.
Preslope---liner--mud bed--curb--There are a lot of different ways of doing things--could you tell me what a 'skip sheet' does?
Old 07-31-2011, 10:21 PM   #7
you only need the felt under the mud if you are doing it on a wood floor. its so the wood doesnt wick the moisture out of the mud and would let the floor move independently of the pan. on concrete you dont need it. just a thin layer of thinset to help stick it to the concrete. and yes california is a strange place
califmonster (08-02-2011)
Old 07-31-2011, 11:21 PM   #8
Monster
slip sheet
It prevents the bonding of the preslope to the concrete floor.
You do not want the preslope to bond in case later down the line you need to tear it out for a new pan. The pan I just tore out had roofing paper between the preslope, and pan. It was very easy to tear out. I want to know if I need the put the diamond wire down for the preslope.
Thats pretty funny skip sheet. look at the post its slip sheet
Old 07-31-2011, 11:23 PM   #9
Monster
Californication
Is a strange place
Old 08-01-2011, 06:09 AM   #10
DIY staff
No mesh needed---
Old 08-01-2011, 08:03 AM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Old 08-01-2011, 10:05 PM   #12
Monster
shower pan on concrete slab.
Danny,
If I put the thin layer of thin set down first I understand the bonding issue.
How hard would it be to tear it out down the line to replace it once it has been bonded. I thought that one reasons for putting a slip sheet of 15 # felt prevented it from bonding . The pan I tore out was 48 years old, and it came out real easy due to the fact there was 3 tab shingles on the bottom of the concrete slab. what do you think?
Old 08-02-2011, 05:57 AM   #13
DIY staff
Danny, How many shower pans have you built? Your methods are unusual.
Old 08-02-2011, 08:25 AM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Never heard of anyone building this type of shower with the hopes that it will fail and will have to be torn out. Showers built correctly will easily last fifty years and longer.
XXX
Old 08-02-2011, 09:41 PM   #15
Monster
If I trowel some thinset before my preslope for a concrete slab. How difficult will it be to remove the shower pan in the future.
I have not done a shower pan before this one, and so far it is coming along ok. The shower has been completely reframed with a new curb in place. I just have had a few different people saying that all I need is a slip sheet of 15# felt because the pan is not going anywhere
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
