Should I Have An Ventilation Fan Behind My Gable Vent? - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-29-2010, 03:50 PM   #1
Rewards Points: 111
Should I have an ventilation fan behind my gable vent?
Right now I have just a gable vent, but I'm wondering if I should install a thermostat controlled fan for the attic space.
luvdairish is offline   Reply With Quote
Old 08-30-2010, 06:38 AM   #2
It can't hurt, but ideally soffit/ridge vents work better and don't use electricity.
Old 08-30-2010, 08:29 PM   #3
Registered User
Rewards Points: 4,894
If these are your only vents, they are least efficient: pp. 602: http://books.google.com/books?id=Z8a...0vents&f=false
If only another gable vent and a powered fan, you will suck the conditioned air from the house through every hole and crack in the top plates and ceiling, possibly other areas: http://www.advancedenergy.org/buildi...%20Studies.pdf
http://www.ronhungarter.com/ventilation_repairs.html
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
luvdairish (09-03-2010)
Gable vent fan: proper circulation. scheenstra Building & Construction 1 07-19-2009 07:59 AM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
Ridge Vent > Gable Vent jelly Roofing/Siding 10 06-09-2008 08:30 AM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
