Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-16-2011, 12:43 AM   #1
Short door
Ok ... Framing a rough door opening in a basement under the floor joist support beam in the center of the house. It has low clearance (78") and I want to try to keep as much as possible. The support beam above is 3 2x16s sandwiched together (4.5" width from underneath). Do I have to nail a 2x4 header up to those and lose another 1.5"? Also, do I need two studs still on either side of the door since no stud would be crippled?
Thanks the advice/help!!
Shaotzu is offline   Reply With Quote
Old 04-16-2011, 09:25 AM   #2
Short door
I'd put the framing on either side as a support for the jamb and backing for the trim. If you don't put it on top, the jamb will be tight to the beam with no room for trim. You would decide if the ascetics is more important then the door height.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Shaotzu (04-18-2011)
Old 04-16-2011, 09:34 AM   #3
old guy contractor
tcleve4911's Avatar
Short door
Always use double trimmers.
Gives nailing for trim and better strength for hinges.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Old 04-16-2011, 10:23 PM   #4
Short door
So any problem then with a header flush to the beams?
Old 04-17-2011, 08:05 AM   #5
old guy contractor
tcleve4911's Avatar
Short door
Nope
Don't even need one.
With the head room issue, I would just install my head jamb directly to the beam.
It will only accept a small piece of trim but ....it's a basement and head room is the priority.
Old 04-17-2011, 10:02 AM   #6
Short door
Originally Posted by tcleve4911
Nope
Awesome ... Thanks for the advice I think I'll head down there and do that today.
Old 04-17-2011, 10:22 AM   #7
old guy contractor
tcleve4911's Avatar
Short door
good luck...
Call if you need a hand.....
Post a pic....
Old 04-18-2011, 01:53 PM   #8
Short door
Originally Posted by tcleve4911 View Post
good luck...
Post a pic....
Thanks! Went off without too much problem! I'll be posting some pics up here in the project section tomorrow I hope!
Can I shorten a Fiberglass door. rjniles Building & Construction 6 12-08-2010 01:57 PM
Masonite front door hard to open and close moopey Carpentry 5 10-04-2010 11:41 PM
1950s Bedroom Door Lock DeeJaye6 Carpentry 3 03-04-2009 01:09 PM
French Doors from Homedepot or Lowes??? johnnytuinals General Discussion 47 01-10-2009 11:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
