Shelving Pin Repair - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-26-2009, 05:24 PM   #1
shelving pin repair
HI
I have some 1/4 inch pins which are breaking down the drilled hole in the 5/8 inch Plywood construction. These were just storage shelves. Is there a collar or female pin available that would allow me to repair these drilled holes that are losing their integrity? In other words insert them in the hole and they would hold the pin?
I think one of the issues is we just used a basic pin, rather than a pin that distributes the weight. But even if I buy new pins, I still need the holes to be repaired and hold their integrity. Any suggestions? KellyO
KELLYO is offline   Reply With Quote
Old 12-26-2009, 05:28 PM   #2
firehawkmph's Avatar
Rewards Points: 1,868
Kelly,
Maybe something like these would work:
http://www.widgetco.com/shelf-suppor...ommets-sleeves
You could probably glue them in place.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 12-26-2009, 07:27 PM   #3
Remodeling Contractor
or fill the hole with a 1/4" dowel and re-drill it.
Old 12-27-2009, 07:46 PM   #4
Rewards Points: 5,336
You might want to lighten the load on these shelves or use an alternative support system. These pin systems are better geared to book shelves and kitchen cabinet shelves.
Ron
Old 12-29-2009, 01:41 PM   #5
Originally Posted by firehawkmph View Post
Kelly,
Mike Hawkins
Perfect, thanks, I could not find these anywhere. Thanks for the source. KellyO
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 03:02 PM
What do you guys think of this roof repair job? darsunt Roofing/Siding 7 08-21-2009 08:43 PM
Ceiling Drywall Repair Question kennykenny Building & Construction 6 12-30-2007 09:18 AM
