Shelf Thickness ? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 12:44 PM   #1
Rewards Points: 18
shelf thickness ?
I'm building a pantry cabinet. The shelves will be 291/2" long by 15" wide. They'll hold assorted groceries...boxes, canned goods, spices. What would be best to use?
I was figuring 3/4" plywood...Would OSB or particle board work without warping?
They'll be painted.
Hawki39 is offline   Reply With Quote
Old 05-21-2011, 12:57 PM   #2
OSB is too rough and particle board will sag over time. 3/4 inch ply is the way to go. if you want them extra sturdy add a piece of 1x2 along the front edge to stiffen them.
Old 05-21-2011, 01:23 PM   #3
Rewards Points: 18
Thanks, I was thinking of the 1 x2 for the canned goods shelf(s)
I'll be getting the plywood.
Old 05-21-2011, 05:45 PM   #4
I'd suggest a reinforced plywood (edges set into a 1x) or 5/4 pine, or use 3/4" hardwood. Canned goods can get heavy
mrgins is offline   Reply With Quote
Adjustable Cabinet Shelf HPHulmeJr Carpentry 1 11-18-2010 11:59 AM
Floating Shelf - 32" TV sacman11 Carpentry 1 10-24-2010 09:19 AM
HELP! Contractor returns in AM! Uneven shelf - how to fix during drywall finish?? MrBoost Drywall & Plaster 6 04-08-2010 02:18 PM
building shelf with questions.. typo Carpentry 2 12-29-2009 06:50 PM
adjustable wall shelf rail amakarevic Building & Construction 1 10-31-2008 12:23 PM
