Sheetrock Butt Ends - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-02-2008, 02:39 PM   #1
sheetrock butt ends
I am wondering if there is a trick to mudding the butt ends of sheetrock.
They always seem to crack after time.
Is there a procedure to use here??
sgtrock is offline   Reply With Quote
Old 01-02-2008, 02:45 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Blacktop mud. Least thats what the old timers tell me, the blacktop mud is "Base Mud" and the green top mud is "Topcoat Mud". The base mud is supposed to be different in density and texture as apposed to the topcoat mud. See what some pro drywallers here have to say. I am curious of their opinion too!
USP45 is offline   Reply With Quote
Old 01-02-2008, 07:46 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
hmmm... If you are seeing cracks, then you are doing something wrong. There are a few things that can cause a butt end to crack.
1.) Are you landing the butt ends on studs? or are you "floating" them?
2.) Do you have enough screws placed on the butt seams?
3.) Are you using pre-mixed compound and mesh tape? If so, then that could be your problem. Use paper tape with pre-mix and mesh with quick dry (hot mud).
There can be other factors that can create cracks at the butt seams as well...
- Build Well -
Old 01-02-2008, 07:52 PM   #4
Another thought: If you are positive that you are applying your tape and your compound per industry standard, then the issue is going to be: How the sheetrock was hung.
When we do contracts that are for taping and coating only, we don't warranty our work because we cannot garuantee that the sheetrock was attached (hung) properly. Poorly hung sheetrock will cause cracking.
I think you need to address that.
Generally, the choice of compound will not make a difference in terms of cracks. Yes, hot mud can be stronger than pre-mixed. But, if you have a crack, the issue is 99.9% of the time - going to be from what is going on underneath ..... "underlying problems"....
- Build Well -
Old 01-03-2008, 04:10 PM   #5
for all the help.Will give those pointers a try.
Sheetrock question Vengence Remodeling 4 07-13-2007 11:42 AM
Sheetrock nightmare MRZ Painting 12 05-25-2007 10:23 PM
pipe leak & sheetrock damage santogr General DIY Discussions 2 03-04-2007 02:44 PM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 09:38 AM
