Shed Window Framing Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 09:06 AM   #1
Shed window framing question
Hi guys. I am working on plans to build a 10x8 storage shed. I would like to build in 3 10" x 18" transom windows up high on both of the side walls (see attached "shed.jpg" for an idea of what I am talking about). I want to get them as high as possible so I have a lot of usuable wall space beneath them. My question is how to frame this. My first attempt was to have king and jack studs for each window (frame_transom_1.jpg), but I end up with a wall that is almost solid studs. My second attempt was to have a common sill and header across all three windows (frame_transom_2.jpg). The results look a little more reasonable, but I am not sure this if this is an acceptable design or not since I haven't run across any examples like this. Would something like this work? Any other suggestions for acheiving this design without using so many studs?
Christian
Shed window framing question-shed.jpg   Shed window framing question-frame_transom_1.jpg   Shed window framing question-frame_transom_2.jpg
ChristianT is offline   Reply With Quote
Old 07-26-2011, 09:51 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
In theory I dont see anything wrong with it. Might double up the sill though.
12penny is offline   Reply With Quote
Old 07-26-2011, 10:27 AM   #3
OK. Thanks. So the sill should be two 2x4s stacked on top of each other?
Old 07-26-2011, 11:29 AM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
I think the upper framing picture is the way to go and since it is a shed I would go with 24" centers on the studs.
That would get rid of the studs under the sills.
Andy.
AndyGump is offline   Reply With Quote
Old 07-26-2011, 11:34 AM   #5
AGWhitehouse's Avatar
Andy Gump has a point that you can get rid of the intermediate studs in the first (king stud) example. The sheathing may have to be trimmed a bit to match the spacing.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-26-2011, 11:38 AM   #6
revised framing based on my comment:
The Following User Says Thank You to AGWhitehouse For This Useful Post:
12penny (07-26-2011)
Old 07-26-2011, 11:58 AM   #7
That's a good idea. Thanks.
EDIT: Actually, I do have one more question :-). Based on my existing design, that would space the king studs 25 3/8" around the window and 8 3/8" between the windows. Does this really matter except for fitting the siding? I suppose it isn't realy a big deal to cut the plywood to fit since it is only a few sheets.
Thanks again,
Christian
Window stool and framing Joe1. Building & Construction 24 11-21-2010 09:54 PM
Question about window companies... bcbud3 Remodeling 3 06-11-2010 12:22 PM
framing a window killingseed Building & Construction 0 04-19-2010 10:53 PM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 09:34 AM
Window Jamb question groundtrac Carpentry 7 11-23-2008 08:09 PM
