Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Prev Previous Post   Next Post Next
Old 10-07-2009, 11:17 AM   #1
Default Shed Roof Truss Question
Hello,
I have a question I was hoping someone may be able to help me with.
I am building a 14' x 16' shed. The walls are all up and I am getting ready to put the trusses in place. I built the trusses in my garage last weekend....raining again....by a design i found in a shed book i bought at Lowes.
The bottom chord spans 14', it is a 12/12 pitch, i made gussetts out of 1/2 ply and used all 2x6 lumber (although the book used 2x4). I live in Maine (SNOW) will be using 1/2" advantech, with clips, and spacing the trusses 24" OC. The roof will recieve asphalt shingles.
My big worry is this....these trusses are all simple triangles, 3 boards, with no king stud or interior bracing at all. Is that crazy? I liked the openess of it, for storage reasons, but as i got thinking about it I started to wonder.
Do you think that I must install some sort of interior brace or will the 2x6's handle this just fine?
This is how they did it in the book, but it was for a shed with a 10' span...not 14' like mine.....but they used 2x4 not 2x6 like mine.......
Thanks for any opinions at all!!!!!!
Mike
Gravel7 is offline   Reply With Quote
More On This Topic
Learn how to adjust the truss rod to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
We are standing in a room that used to be a carport when the house was originally built and somewhere along the line one of the owners has turned this in to a living quarters, whether it be a bedroom or a family room or whatever and we are in the process... Read More »
Composting is a great way to take leftover organic material from your household and use it in your yard and garden. To keep the composting process moving, it is important to keep the decomposing materials turned over. It’s a relatively simple... Read More »
Hi, this is Jon and in this clip we will be installing our fixture box. Now, with the can light that we pulled out, the diameter is about six inches. However, the diameter for our mounting plate is only about four inches. Now, because our opening is so... Read More »
When you see a dentist for in-office whitening, what usually will occur, is that your dental office will take impressions of your teeth. And that just is a very simple process that involves the impression material being put into the trays, and you may be... Read More »
Installing roof tile. Rafter span question. meltdowndave Roofing 0 08-23-2009 10:25 AM
Pre Fabricated Truss for Patio roof seth Building & Construction 6 07-18-2009 09:23 PM
HELP - Finishing Row on a Shed Roof Makes More Work Roofing 5 06-25-2008 07:27 PM
steel roof question kindrngentlr13 Roofing 5 06-18-2008 01:29 PM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 09:28 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
