Shed Roof Framing - Rafter Size Recommendations? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 09:40 AM   #1
Rewards Points: 262
Shed roof framing - rafter size recommendations?
I am planning on building an 8'x12' shed this summer. It will sit on a portion of my compacted gravel driveway and have a single plane, sloping roof (shed roof). The front face of the shed will be 12' long, have a 6' width of double doors, and be approx. 10' high. The rear face will be approx. 8' high. My question is: Many shed kits use 2x4's at 24" O.C. to frame their roofs, usually with a gabled truss. Since I live in CT, and plan on a simple shed roof, am I better served using 2x4's at 16" O.C. for the roof (with cross blocking for more rigidity), or 2x6's at 24" O.C.? I am opting for the 2x6's, so I can create a birdsmouth connection at the top plate, but I don't want to spend money unnecessarily. Are 2x6's overkill? I did have 4' of snow on my roof this winter...
Thanks for all advice.
tpagel is offline   Reply With Quote
Old 04-14-2013, 10:23 AM   #2
funfool's Avatar
Rewards Points: 534
Go with the 2x6, 2x4 make a really crappy shed roof. They are great for a engineered truss system.
What you really need to do is check the span of the 2x6 and the load calcs of what it will hold. Then figure out what 4 foot of snow weighs.
I would not consider 2x4
2x6 would be the bear minimum I would use.
You may find with your load calcs that the weight of the snow is pushing the limits of the 2x6. You may want a 2x8.
I only have memories of snow living in Albuquerque
Seems to be a big difference in weight from a nice fluffy dry snow, to a wet heavy snow.
If you ever think you may want to putter around in the shed during the winter, will be able to add more insulation with the 2x8.
Here we use 2x12, not for strength, just to meet code for insulation in a living space.
funfool is offline   Reply With Quote
Old 04-14-2013, 10:29 AM   #3
joed's Avatar
Rewards Points: 13,750
2x4 in the form of a truss does compare in any way to a 2x4 used as a straight rafter. For a 12 foot span a 2x8 is called for.
The Following User Says Thank You to joed For This Useful Post:
jagans (04-14-2013)
Old 04-14-2013, 10:49 AM   #4
Roofmaster
Rewards Points: 2,210
A truss is designed to break down applied loads and distribute them throughout the truss to the foundation. A single span rafter has to deal with the applied loads within its structure. You may want to re-think the 8 foot dimension if you can, that's pretty shallow.
Old 04-14-2013, 11:18 AM   #5
GBrackins's Avatar
Rewards Points: 2,108
two questions, what is the ground snow load requirement for your area, and what is the slope of the 8' span shed roof?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 04-14-2013, 12:39 PM   #6
Rewards Points: 262
Thanks everybody....The ground snow load where I live is 30 psf. I think the slope of the roof will be about 3:12. I chose the 8' depth of the shed for floor panel material efficiency. The 4' of snow on the roof of the house has happened twice in 5 years, but the shed is easily cleared with a roof rake, as opposed to the house, whose roof we had to shovel.
Old 04-14-2013, 01:42 PM   #7
GBrackins's Avatar
for 30 psf snow load, 3/12 pitch roof over a 8' span the minimum rafter would be something like a #2 spruce 2x6 at 16" o.c. I'd strongly recommend 2x8 at 16" o.c. however. the difference in price isn't that much for your shed, and you'd have a stronger roof for those high snow events.
just my opinion
Gary
Old 04-14-2013, 06:51 PM   #8
Rewards Points: 262
Sound advice. I'll go with 2x8's at 16" O.C. for the rafters. I appreciate everybody's help!
Old 04-14-2013, 08:06 PM   #9
Roofmaster
If you have the room, I would double it to 16 feet. Stuff Grows
Old 04-14-2013, 11:48 PM   #10
Registered User
Rewards Points: 526
http://publicecodes.cyberregs.com/ic...002_par023.htm
Gary
Old 04-15-2013, 07:20 AM   #11
AHH, SPANS!!!
Rewards Points: 1,166
might want to plan on some overhangs with your rafters that go past the top plates then connect the rafters to the top plates with hurricane clips...
hand drive is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Recommendations for roof type when reroof daluu Roofing/Siding 24 12-07-2012 02:23 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 01:30 PM
awg size for 60' underground line from house to shed for 60 amp capslock Electrical 5 06-09-2010 10:31 AM
