-   -   Shed doors (http://www.diychatroom.com/f14/shed-doors-23222/)
Jshakour 07-05-2008 10:44 PM
Shed doors
I have an aluminum shed and the doors that slide left to right. The doors got all beat up and wouldnt close right. Then a strong winter storm really threw them out of wrack, followed by a thunder storm shorty after.
I took the doors off and was thinking about building wooden doors, the entire front of the shed would be rebuild as a stud wall with an opening for doors and be attached to the existing metal walls, my questions is this...
how to attach the bottom part of the stud wall to the cement floor... Tap cons? Red heads? Other?
-J
buletbob 07-06-2008 09:24 AM
Tap con's would be fine!
Jshakour 07-06-2008 09:59 AM
can you tell me the proper way to use tap cons as I have never used them before?
-J
buletbob 07-06-2008 10:10 AM
you can find them in HD, Loews's they come with there Owen drill bit and hex head driver. if you are using 2x lumber I would suggest 2-1/2 - 3" tap cons. place your bottom plate on your mark and drill through the plate into the slab.
What I use that works best for me is an impact driver to set them . A drill driver works fine, but found they like to snap the shanks of the tap con's. GOOD LUCK BOB
Renovator,LLC 07-06-2008 05:04 PM
Tapcons would probably be ok, but because the wall will support the door, and the racking that it might produce, I would be inclined to sink a few reheads in the slab just to ensure the plate does not move. I've seen more than a few tapcons break off, though poor installation practices were primarily to blame.
Jshakour 07-06-2008 09:50 PM
lets take this one step further......
how hard is it to build trusses?
any direction would be great!!!!!!!
-J
