Shadow Box Molding On Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 04:01 PM   #1
Shadow box molding on stairs
I'm installing shadow box molding up stairs. How can I cut the extreme obtuse mitres acurately? I have just be marking angles on walls and cutting them in half. I then take the molding and make marks on each side of molding and make a straight line. I then have be holding molding on mitre saw and cut free hand, trying to cut right on line.
There must be an easier way?
James983 is offline   Reply With Quote
Old 03-27-2010, 04:16 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Miter saws swivel to allow for the cuts you desire. There should be no need to hold it as you describe.
Compound miter saws swivel and tilt to achieve 2 angles at once.
DM
Old 03-27-2010, 04:48 PM   #3
you will need to build a jig to use on your miterbox or table saw. a miterbox will not cut steep enough
you will need to find the angle/ intersection of the two pieces, subtract that from 90, set your saw to that number and hold your piece perpendicular to your miterbox fence
The older I get the better I was
Old 03-27-2010, 05:26 PM   #4
Thanks. Didn't even consider table saw.
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Devil in the Details: Molding, Stairs, and Tile to Carpet moodwaffle Flooring 4 04-04-2011 02:23 PM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 02:13 PM
Strengthening stairs with less support HitLines Remodeling 1 10-29-2009 11:45 PM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
