Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-24-2009, 01:13 AM   #1
jackie treehorn's Avatar
Serving bar size
I'm building a serving bar outside between two pergola posts, since it's basically the same as an indoor one other than material the size should be the same. Problem is everywhere I look I can't find any given specs as to what standard is for the height and width, I was gonna do 12" wide but am afraid this will be a bit small. Any suggestions?
jackie treehorn is offline   Reply With Quote
Old 04-24-2009, 07:28 AM   #2
Serving bar size
Width between 20-24". Height depends on the seating. Bar stools or chairs?
Ron
Old 04-24-2009, 11:38 AM   #3
Serving bar size
bar stools for sure, I just want something most people could lean against and set down a plate if there wasn't enough seating etc
Old 04-24-2009, 03:00 PM   #4
Serving bar size
Not all stools have the same seat height, so get the stools you like and plan the serving bar height accordingly.
Ron
Size of whole house fan needed Doug Crf General Discussion 20 02-26-2011 12:29 AM
Room size X floor tile size deck hand Flooring 4 04-08-2009 05:42 PM
duct work size justmefixin HVAC 2 09-20-2008 07:59 PM
NEC uses building size?????? hhiibel Electrical 14 08-08-2008 01:19 PM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 06:00 PM
