Misplaced strut mounts can wear on a tire and cause a dangerous blowout. Replacing the strut mounts after a blowout requires a fair amount of time, but you can do it yourself if you have any experience with auto repair. The mount is located 8 to 10... Read More »
Hello. My name is Russell Kompinski and on behalf of Expert Village we are going to learn how to purchase and assemble a skateboard. So now after having your bearings installed you just simply slip that washer right on the shaft, put the wheel on the... Read More »
In this segment I want to outline the importance of tightening bolts, properly, in order to get it mounted up, securely to your vehicle. You can just imagine riding down the road and you've got your most valuable possession, your gigantic boat, behind... Read More »
In this clip, we're going to talk about the proper service procedure for removing and replacing a front strut on a front-wheel drive vehicle. In this step, we're going to talk about the proper service procedure for removing our strut from our knuckle and... Read More »
Hi, this is Jon, and in this clip we'll be talking about the portable shop table. As you begin to accessorize your wood shop, you might also want to think about purchasing a portable shop table. You'll notice on one side there are wheels at the base of... Read More »
