09-12-2012, 07:28 AM
#1
see attached photo on exterior stairs...how to do?
can't find info nowhere, nohow, anybody done this?
09-12-2012, 07:49 AM
#2
Where did you locate the photo at? Looks like a pretty specific project. Doubt anyone but where you found the photo at would have this exacy setup.
09-12-2012, 07:55 AM
#3
Looks cool but not very safe, legal or functional.
A deck that high needed railings to pass code.
Picture how you would be going up and down those steps.
The bottom one there showing has it level with the grade, 2X 's are not below grade rated, and any composite decking I've delt with states there needs to be at least 12" of free air space under it so it will not mold up.
What your not seeing is the hidden post supporting the deck above that runs through the deck below.
09-12-2012, 08:03 AM
#4
Moderator
There’s really nothing complicated there, you just treat each of those landings as individual decks.
The first (lowest) one at grade is hopefully sitting on a bed of crushed rock. The second one would require three separate post and footings to support the three corners with the forth corner being supported off the first step. The third looks to be supported with a ledger off the main deck and would require only one additional post and footing.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
09-12-2012, 08:14 AM
#5
Look close at that picture Kwick, the decks in the picture do not make contact.
I do agree with you that the decks below could act as the third post, but that's not what's shown in the picture.
09-12-2012, 08:27 AM
#6
STAFF
If it were mine I would cut the point that overlaps to a 45 degree so there would be a step in code instead of stepping off of a point and as said I would install rails to be safe and be in code.
What is it you are wanting to know, how to build, how to be in code or something else.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
Reason: added
The Following User Says Thank You to BigJim For This Useful Post:
09-12-2012, 08:29 AM
#7
Moderator
Not if it's under 30".
Hard to tell exactly how they did it with the shadows but I'm sure that one is just sitting on the other even if the support is back there a few inches.
09-12-2012, 08:31 AM
#8
And what's code on exterier stair width?
09-12-2012, 08:43 AM
#9
Jim's thought on this makes a whole lot of sense. I have seen quite a few steps like that, and while they may have a certain appeal at first glance, they are, in my opinion, impractical and unsafe. But, knock the corners off, as Jim mentioned, and you maintain the basic premise, while building something that is usable.
09-12-2012, 09:30 AM
#10
if the clear area of those "steps" is at least 36" x 36" then they are landings and not steps. of course there is a riser height in between them, with most code requirements being a maximum of 7-3/4" (8-1/4" in Massachusetts). There would be no requirement for handrails since you do not have a run of treads or flight with four or more risers.
as kwik stated, guards are only required when the floor of the deck is more than 30" above the adjacent ground.
Gary
"You get what you pay for, and sometimes free costs more!"
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
