Secure Bed Loft - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-10-2013, 09:34 AM   #1
Rewards Points: 155
secure bed loft
I bought a single twin bed loft for my daughter- it's metal. it's the kind with just one bed on top and you can put desk/couch etc under it- the issue is- its very wobbly when she sleeps on it-
I was trying to think of ways to secure it -but fastening it to the studs on the wall to me maybe not the best? I don't know- i can picture it moving and working it's way out possibly damaging the drywall...... any thoughts?
Huskyfan68 is offline   Reply With Quote
Old 09-10-2013, 09:48 AM   #2
I had a similar situation about 20 years ago.
What I THINK I recall doing was: I used U-bolts to secure the vertical steel posts to 2X4s placed horizontally (countersinking the holes so as to have a flush rear surface), then screwing the 2X4s to the wall studs.
Before putting it all together I painted the 2X4s to match the wall.
When I removed it years later I had but a few screw holes to spackle
RoyalAcresRod is offline   Reply With Quote
Old 09-16-2013, 10:38 AM   #3
Rewards Points: 155
ok thanks- I have the loft bed (from IKEA)- made of metal (not sure what type)- I want to modify the frame a bit since I need to get a couch under it- I was thinking of making the actual frame wider (using wood) has anyone ever modified (altered, combined) a standard metal frame with wood (2x4's) to sort of customize the frame?
Old 09-16-2013, 12:05 PM   #4
What is the frame construction? Is it metal tubing?
Old 09-16-2013, 12:23 PM   #5
Rewards Points: 155
yes- metal (not really tubing)- but metal- I wanted to make the overall width of the bed bigger- (right now it's like 75.5" wide)- Not sure how to do that without some serious "McGyvering"
Old 09-16-2013, 12:26 PM   #6
When you say, "Not really tubing" what do you mean? I was asking about tubing as it's easy to cut and slide a slightly smaller piece inside the tube to make it longer.
Old 09-16-2013, 12:28 PM   #7
Rewards Points: 155
the ends are round like tubing- the frame pieces that run width-wise look more like metal
1 x 3's
Old 09-16-2013, 01:43 PM   #8
You might be able to do the same thing with slightly smaller than 1X3 stock. You'll want pieces to slide in as long as possible.
I'd like some ideas for framing a shed loft. SHIFT Building & Construction 10 08-15-2012 08:51 AM
bunkie gable roof need to tie into ceiling (loft) joists? mrfitz Roofing/Siding 2 06-25-2012 11:32 AM
what is better for a small room " junior loft or a full loft ?" irishguy76 Carpentry 3 05-23-2011 10:17 AM
Twin Size Loft Bed construction.. for a dummy what_silliness Building & Construction 2 01-15-2011 03:53 PM
How would i finish this loft???? (pics) oregonrebel Building & Construction 3 03-31-2007 09:01 AM
