Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-16-2006, 11:49 AM   #1
sealing wood
what could I seal the back side of a finished piece of oak with that construction adhesive will stick to?? thanks
farrington135 is offline   Reply With Quote
Old 10-18-2006, 08:26 PM   #2
sealing wood
I would advise looking at the label on the adhesive you plan on using. It should tell you the conditions in which it will work. I would imagine an oil sealer would not adhere as well as some other types. Also look at different types of sealers. Make sure you get the right one for the conditions it will have to endure such as rain, snow and temperature changes.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Wood Under Door Sill is Rotted rgmetro Building & Construction 14 11-19-2010 01:24 AM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
Permanent Wood Foundation Question opee Building & Construction 2 03-19-2007 10:27 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
