Sealing The Hole In Exterior Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 04:16 PM   #1
Sealing the Hole in Exterior Wall
Hi there,
My husband and I need to close off two old stove/oven vent ducts on the exterior wall. They are about 12" x 5" rectangle cut outs. What is the best material and best way to go about this?
We were thinking about using a cut piece of OSB to fill the hole, then fill the edge gaps with some caulk, put Tyvek tape around the edges, and lastly screwing in a piece of overlapping plywood to anchor it to the inside of the exterior wall (almost like a flange). Will this be an effective approach?
Any advice would be helpful. Thanks so much!
Lollymagoo is offline   Reply With Quote
Old 03-05-2011, 05:12 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Read your post back to yourself and see if you would be able to answer that question with the info given.
What's the siding?
What's the interior finish?
We need pics, we need pics, we need pics, we need pics........
tcleve4911 is offline   Reply With Quote
Old 03-05-2011, 07:03 PM   #3
Rewards Points: 5,336
What you have determines what you do.
Ron
Old 03-07-2011, 04:17 PM   #4
Originally Posted by Lollymagoo View Post
Hi there,
I had a similar problem on an aluminum sided house. I cut a suitable patch from aluminum flat stock. Ran a bead of silcon caulk around the perimeter of the hole and the pop riveted the patch in place.
Self drilling, self tapping metal screws would work also! This would also work on vinyl. Although with vinyl, it would also be possible to remove some sections and install new.
Old 03-07-2011, 04:26 PM   #5
Sounds good to me but then I have no idea what you are doing. A picture is worth a thousand words and you can quote me on that
masterofall is offline   Reply With Quote
Huge hole in foundation texasgolfer Building & Construction 2 01-07-2011 05:55 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 09:26 AM
sealing a masonry hole for a wire mcvane Electrical 2 06-18-2008 09:18 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
