Scribe Cutting Oak Stair Treads - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-17-2008, 07:21 AM   #1
Getting ready to cut these oak stair treads to fit and will need to scribe them against the inside skirt board. Looking at these treads, I don't think my little Craftsman jig saw is going to do the trick and I see this as an opportunity to aquire a new tool. Whats best for the job?
kcdave is offline   Reply With Quote
Old 03-17-2008, 03:59 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
We use this tool. Works Great. Very reasonable price:
http://www.collinstool.com/base.php?...gauge_ends.htm
Other than that, for power tools, you can use a skill saw or a sliding compound saw.
Here's the last set of stairs we used the Collins Tool on:
- Build Well -
Old 03-18-2008, 07:13 PM   #3
Remodeling Pro
If the scribes aren't straight use your jigsaw to get the cuts within 1/16th of the pencil mark and then use a belt sander to finish them out. If your craftsman jigsaw can't hack it I'd recomend a Bosch. Make sure your jigsaw blade cuts on the up stroke or it will "push" the oak away from the saw and make it "jumpy".
orson is offline   Reply With Quote
Recessed pull-down attic stair BlueTheCow Carpentry 4 10-31-2007 05:54 AM
who has "nice" stair edging? mattroos Flooring 8 09-07-2007 10:34 AM
Cracked Stair Treads pickel011 General DIY Discussions 1 12-27-2006 03:31 PM
Stair help - Am I going about this correctly? jtnaylor Flooring 9 12-05-2006 03:02 PM
