Screwing Hinges To Ends Of Plywood - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 04:38 AM   #1
Rewards Points: 866
Screwing hinges to ends of plywood
The plans for a miter saw stand I am building call for plywood wings and extension arms to be attached to the edge of the stands top with 3" light duty T hinges.
The top of the T is fastened to the but end of the stand's 3/4" plywod top with 3 drywall screws. The wings are supported by swing out gussets, when raised. When lowered, the hinges bear the entire weight of the wings.
That edge is 2" from the top's nearest point of support, the cabinet. I wonder how well those screws are going to hold or if the plywood is going to rip out. (Pilot holes will be drilled) The wings with extensiions are fairly heavy. I would estimate that each one is made from a third of a full panel of 3/4" plywood.
I wonder if I should reinforce the top with a 2" wide piece of 3/4" plywood fastened to the bottom of the top's overhang and to the side of the base on which the top rests.
Here is the stand. Unless it looks like the plan is definitely weak, I am inlcined to just follow it, but I don't see any downside to supporting the left and right sides of the top. I am also wondering about adding some red oak to the edges with screws and glue, and then attaching the hinges to the oak. What do you think?
Klawman is offline   Reply With Quote
Old 12-09-2009, 07:54 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
I'd go with the red oak option. I've never seen screws that held all that well to the edge of a piece of plywood. Either tongue and groove the oak to the plywood or biscuit join it. If you are screwing through the plys, that is different. They should hold. Especially a course threaded screw.
Old 12-09-2009, 08:30 AM   #3
Chicago, IL
Michael Thomas's Avatar
Through-bolts with recess heads and fender washers?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 12-09-2009, 10:13 AM   #4
47_47's Avatar
Rewards Points: 44
Can you mount the hinge to the under side of the table and the wings with through countersunk machine screws, washers and nuts? If not go with Maintenance 6 suggestion and band the plywood with a solid hardwood.
47_47 is offline   Reply With Quote
Old 12-09-2009, 11:43 AM   #5
Rewards Points: 866
I am glad that I aked. The design of the table won't allow for mounting the hinges to the bottom of the table. (The pivot point of the hinge pin has to be located at the level of the table's top surface.) I know what bisquits are but don't have anything for recessing the ply so it will accept them. However, I believe I can cut a tongue and groove with several passes of on my little bench saw. I will set it up to cut 3/16" on the top and bottom of the table and make enough passes to make a 3/8" x 3/8" tongue. Then I will set the blade to cut a 3/8" x 3/8" wide groove down the center of one side of a piece of 3/4" red oak. In addition to gluing I will use 3 drywall screws and I will drill pilot holes. Thanks. I may just go ahead and "band" the front and back edges.
Tags
plywood , saw stand
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 01:44 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 07:47 AM
Subfloor repair Dave321 Flooring 3 09-16-2009 09:59 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
