#1 |
Screwed up casing staining with filler
OK, I already screwed up by filling all my nail holes with minwax wood filler BEFORE staining. However, I have only stained one isolated window (of 8). The splotchy, crappy look of the first stained window gave me impetus to research, which of course yielded negative results. My question: can I salvage the remaining windows by sanding the crap out of the filled areas before staining? If not, is there any other way I can avoid the chicken pox effect o this?
#2 |
journeyman carpenter
you should have stained and put one coat of clear on the wood before you even started cutting.. once its on the wall use color matched wax sticks to fill the holes. and touch up the stain on the cuts before its installed
#3 |
Yeah, I learned that doing my research after the fact. Any suggestions on what to do to remedy the situation?
#4 |
theres nothing you can do now.. the oil is in the wood.. unless you feel like going with pain instead of stain
#5 |
Crap.
| Display Modes | |
| Help with adding custom color to wood filler | 4thDimension | Carpentry | 5 | 10-14-2011 02:46 PM |
| Need help making a 'back band' around window/door casing. | RickDel | Carpentry | 3 | 07-15-2010 04:13 PM |
| Staining Wood - When to use wood filler | markronz | Carpentry | 8 | 03-04-2010 08:15 PM |
| Aluminum Casing on Front Porch Pillars | DRoby | Building & Construction | 1 | 09-06-2009 06:13 PM |
