-   -   Screwed up casing staining with filler (http://www.diychatroom.com/f14/screwed-up-casing-staining-filler-172172/)
NotoriousCDB 02-17-2013 11:42 AM
OK, I already screwed up by filling all my nail holes with minwax wood filler BEFORE staining. However, I have only stained one isolated window (of 8). The splotchy, crappy look of the first stained window gave me impetus to research, which of course yielded negative results. My question: can I salvage the remaining windows by sanding the crap out of the filled areas before staining? If not, is there any other way I can avoid the chicken pox effect o this?
woodworkbykirk 02-17-2013 12:39 PM
you should have stained and put one coat of clear on the wood before you even started cutting.. once its on the wall use color matched wax sticks to fill the holes. and touch up the stain on the cuts before its installed
NotoriousCDB 02-17-2013 07:00 PM
Yeah, I learned that doing my research after the fact. Any suggestions on what to do to remedy the situation?
woodworkbykirk 02-17-2013 09:11 PM
theres nothing you can do now.. the oil is in the wood.. unless you feel like going with pain instead of stain
NotoriousCDB 02-17-2013 09:52 PM
Crap.
