Screw Or Other Fastener Recommendation - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 11:00 AM   #1
Screw or other Fastener Recommendation
See image above. I need to affix parts A and B with some sort of screw or other fastener through the holes on the right side of B. The catch is that I cannot harm, damage, or alter A in any way (i.e. put holes in it).
Can you recommend something for this application?
Thanks!
jimtyph1 is offline   Reply With Quote
Old 05-05-2011, 12:45 PM   #2
i think i would want to know what A and B are before i recommend anything.
my first thought is that what you are describing is impossible with a screw, bolt or nail.
depending on what it is, how about you pad the rest of the slot and glue it?
wombosi is offline   Reply With Quote
Old 05-05-2011, 02:27 PM   #3
Rewards Points: 5,336
Thanks!
In the space to the right of "A" place a metal plate as wide as the space.
Tap the hole in "B" or use a metal insert if it's wood. Screw a bolt in "B" and it will push the plate against "A" holding it in place. Use locktite or a lock washer on the bolt so it stays tight.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
oh'mike (05-09-2011)
Old 05-05-2011, 02:55 PM   #4
Too Short? Cut it Again!
Agreed. With almost everybody so far. Without knowing what A and B are and how tall? I would put a spacer of metal, hardwood, corian, semi rigid rubber or clear lexan in place. I guess you could put screws through the pilot holes shown.
This smells of an art presentation to me.
Again, without knowing all the details, I might also be willing to try just wrapping the base in a rubber like material and press it in place.
Does whatever this have to be presented with the backside against the back edge or is the whole pocket fair game?
Old 05-05-2011, 04:38 PM   #5
Rewards Points: 1,596
I'd like to know what the slot A is in is so much larger than A unless it is not drawn to scale? If A pivots on the bolt, it may need a bushing or sleeve to prevent wear?
bob22 is online now   Reply With Quote
Old 05-08-2011, 07:34 PM   #6
It is hard to say without knowing what it is and what the materials are.
henrybo is offline   Reply With Quote
Old 05-09-2011, 03:26 PM   #7
SteelToes's Avatar
Rewards Points: 150
A = glass
SteelToes is offline   Reply With Quote
Old 05-09-2011, 04:36 PM   #8
Carpenter
dtsman's Avatar
Do it like a Christmas tree stand, use a bolt with a rubber stopper on the end.
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 05-09-2011, 06:02 PM   #9
Rewards Points: 150
Put a 1/4" tee nut on the inside of holes in B, then screw a 1/4-20 Swivel Screw Clamp through B from the outside, then place a swivel screw clamp foot on the end of the swivel screw clamp then tighten up on A. Since you didnt give all of the dimensions don't know if this (swivel screw clamp foot) will fit between A & B.
josall is offline   Reply With Quote
Old 05-09-2011, 07:51 PM   #10
biggles's Avatar
B look like a mounting to hold A in place wonder the weight of A? 2 wing nutswith washers on the bolt head thru B and finger tighten them and sock it up with a stubby screwdriver
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
