Scratching On Treks Decking - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-21-2011, 12:35 PM   #1
Scratching on treks decking
WE HAVE TREKS ESCAPES DECKING. VERY VERY DISAPPOINTED WITH THE WAY IT SCRATCHES - SUMMER FURNITURE HAS TO HAVE RUBBER BOTTOMS -NOTHING CAN BE DRAGGED ON DECK LIKE A HOSE. TWO WINTERS IN A ROW THE NAILS IN CERTAIN BOARDS POPPED THRU. yES IT HAS BEEN INSTALLED PROPERLY ( ACCORDING TO DIRECTIONS. IS THIS A COMMON PROBLEM-HELP WE ARE JUST DISCUSSED OVER THE WHOLE DECK
NYDUCK is offline   Reply With Quote
Old 04-21-2011, 02:37 PM   #2
Rewards Points: 5,336
Dragging things across a deck or a floor will cause scratches. If they're not too deep you may be able to buff(lightly sand) them out.
Screwing down the raised boards will keep them down.
I would have not used nails on the deck.
Ron
Old 04-22-2011, 06:35 AM   #3
Next Time...New Build
Rewards Points: 150
They make self tapping/countersinking screws for this application. They are a little pricey but well worth it. I thought the mfg specs for Trex was to use screws anyway....?
RickyBobby is offline   Reply With Quote
Old 04-22-2011, 06:37 AM   #4
Rewards Points: 150
Also, if you did use screws and they are popping out, then the wrong screws were used, they were driven in way too deep, or the framing was off which resulted in undo pressure in certain spots of the decking board causing the boards to pull off.
Old 04-22-2011, 09:13 AM   #5
mem
Rewards Points: 156
According to the Trex installation instructions, only screws are recommended as fasteners for ALL Trex products--see page 16. On the same page it states using any non-recommended fastener voids your warranty! And any sanding will also void the warranty.
mem is offline   Reply With Quote
Old 04-25-2011, 06:32 AM   #6
Ironlight's Avatar
We have a Trex deck and it has been near bulletproof. We have two hyper, good-sized dogs and they tear across the deck all day long on their way in and out of the house and there is not a mark. No scratching from furniture and my teenaged daughters and their friends who make heavy use of the deck are certainly not gentle.
Ironlight is offline   Reply With Quote
Old 04-25-2011, 07:13 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
so do you have Treks or Trex?
tcleve4911 is offline   Reply With Quote
Old 04-25-2011, 08:30 AM   #8
mem
Rewards Points: 156
Ha! From his description it sounds like the OP got the TREKS on sale at OddLots!
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
Deckmaster--will it work with 3/4" hardwood decking? jbeall Building & Construction 8 03-15-2011 09:05 AM
Suggested Subflooring over pressure treated decking 112690 Building & Construction 2 10-19-2010 07:54 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
Plastic decking? kcrossley2 Building & Construction 4 10-08-2007 10:59 AM
