Scissors Truss - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 12:29 PM   #1
Scissors Truss
I am trying to figure out what pitch the outside of a scissors truss will be if the inside is a 3/12 pitch
Schmidt is offline   Reply With Quote
Old 10-20-2010, 12:33 PM   #2
kwikfishron's Avatar
Rewards Points: 586
You can order it almost any pitch you want.
kwikfishron is online now   Reply With Quote
Old 10-20-2010, 12:40 PM   #3
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I think what he is saying is that the pitch of the bottom chord is 3/12 and he is wondering what the pitch on the top chord needs to be. I know that it has to be greater than 3 (prolly on the realm of 4-5). Call your local lumber supply and ask them. They'll even design it for you. If your just looking for an idea they would be able to help you out.
WirelessG is offline   Reply With Quote
Old 10-20-2010, 01:20 PM   #4
Thanks for the info. I think I got what I need.
Old 10-20-2010, 09:17 PM   #5
firehawkmph's Avatar
Rewards Points: 1,884
Schmitty,
When I was building houses we used a lot of scissor trusses. Normally the truss company would make the inside pitch half of what the outside pitch was unless you told them otherwise. You can take a framing square and a 24" level up on the roof and find out pretty quick. Lay the long leg of the square on the roof with the short leg on the bottom. Hold the level so one bottom edge is on the 12" mark on the long leg, then level out the level and see what number on the short leg you line up with, sighting along the bottom edge. If it lines up with the 6" mark, you have a 6/12 pitch.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Pre Fabricated Truss for Patio roof seth Building & Construction 6 07-18-2009 07:23 PM
Hurricane Brackets (truss brackets) AndrewF Building & Construction 4 04-06-2009 01:23 AM
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
2nd story ledger to floor truss fisherk Carpentry 1 10-18-2008 12:08 PM
Gambrel Truss Dormer and Ladder Framing? fauer Carpentry 3 09-30-2007 07:36 PM
