Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-07-2010, 01:45 PM   #1
Electrician
Proby's Avatar
Sawzall with Remgrit blade for cutting cement board
I was wondering how a sawzall with a Remgrit blade would work for cutting cement board? I know you can just score the board and break it, but I would prefer smooth cuts. I could use a grinder, but that seems like more work and it's very dusty.
Opinions?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-07-2010, 08:35 PM   #2
Super Moderator
I use a wet cutting circular saw--with a soaking wet sponge slapped up against the blade.
Search results for: 'tile saw'
Use a smooth blade--the notched one tears up the sponge.--Mike--
Old 08-07-2010, 08:56 PM   #3
Electrician
Proby's Avatar
Normally I jump at any chance to buy a new tool, but after I'm done with my own bathroom I'm not sure if I'll ever need a wet cutting saw again.
Old 08-08-2010, 10:28 AM   #4
uva uvam videndo variafit
WirelessG's Avatar
You could always rent one for a day.
I wonder how a dremel would do on cement board with a tile bit.
WirelessG is offline   Reply With Quote
Old 08-08-2010, 10:34 AM   #5
firehawkmph's Avatar
I use a carbide tipped hand scoring tool for big cuts. Score it a few times and it snaps off pretty easy. For notches and any small cutouts, I just use my old sawzall blades with my sawzall. It goes right through. It will wear the teeth down after a few cuts, but that's why I use my old blades, then finally throw them out.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 08-08-2010, 04:12 PM   #6
Handyman
I'm with Mike..works like a charm. Saw is only $100 and you may use it later for tilework. Besides, owning a wetsaw is like owning a pickup truck...which is like winning the lottery...you be surprised how many friends you had and didn't know about
canadaclub is offline   Reply With Quote
Old 08-08-2010, 05:02 PM   #7
Super Moderator
That little saw only costs $29 on sale--$39 regular price
Old 08-08-2010, 05:47 PM   #8
Handyman
Ok Mike, and I make the cheque out to???? HD here robbing me!
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 07:29 PM
Cement board Ron Franck Drywall & Plaster 1 01-16-2010 08:01 PM
Laying cement board oguevarra Flooring 18 12-16-2009 10:21 AM
Moisture Barrier behind cement board code? scoot_gt Building & Construction 8 09-29-2007 09:53 PM
Bathroom cement board dah General Discussion 2 07-11-2006 07:25 PM
