Saw Cuts Inaccurate Angles - Carpentry - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 07:18 PM   #31
the Musigician
DangerMouse's Avatar
...but i still know what the problem is... *mumble-grumble*
DM
Old 06-25-2009, 07:20 PM   #32
Jay123's Avatar
Jay123 is offline   Reply With Quote
Old 06-25-2009, 07:21 PM   #33
Rewards Points: 780
Yeah, I'm pretty sure the boards are flat.
ooh! ooh! call on me! call on me! i know!
Yes, young man in the front row with your hand in the air? LOL
gma2rjc is offline   Reply With Quote
Old 06-25-2009, 07:22 PM   #34
Jay123's Avatar
Old 06-25-2009, 07:23 PM   #35
Jay123's Avatar
so there is no gap if you put a straight edge across the width of the board?
Old 06-25-2009, 07:24 PM   #36
Rewards Points: 780
The problem isn't that it's a Black & Decker. The problem is that it's a Fire Storm that cost all of $99. Even a B&D would have been a step up I think. LOL
Old 06-25-2009, 07:25 PM   #37
Rewards Points: 780
nope, no gap. I've tried it on several boards and even some MDF trim. They all cut the same way.
Old 06-25-2009, 07:27 PM   #38
the Musigician
have you ever cut a board with your saw tilted like that before?
DM
Old 06-25-2009, 07:29 PM   #39
Jay123's Avatar
then the space-time continuum is messed up
Old 06-25-2009, 07:34 PM   #40
Rewards Points: 780
Yes, I've cut a few boards with the saw at that angle before. And I almost always have the same problem, but I really don't want to make any more cuts until I can get it right.
Well.....that would explain a lot of things around here.
Old 06-25-2009, 07:43 PM   #41
the Musigician
Tah-Dah!
and the answer is...! ok, ok...
looking at the piece on the table, you start out ok, but drag the blade down into the piece, thereby creating that weird cut.
it'll take a few tries, but tip your head as you cut and let the saw do all the work. be sure it's completely revved up before starting the cut. try it, i'll bet you get a perfect cut. if all your measurements are correct, then it's not the saw.... it's your toolnewbieitis acting up again is all... Po)
DM
Old 06-25-2009, 07:48 PM   #42
Jay123's Avatar
and make sure no one has been cutting re-bar with that blade
Old 06-25-2009, 07:50 PM   #43
If the saw is consistent you can, in principle, adjust out the errors and offsets.
Your angle measuring devices should have 5x or 10x better accuracy than what you're checking.
The geometry we all can help you with, and using plywood will give you dimensional stability. You just need straightedges, a ruler and a calculator.
Probably the best you can do with ordinary effort is 1/16" in 6", about 0.6 degree.
A saw blade is supposed to lie in a plane, but a dull blade will deflect with pressure so the blade surface becomes curved. I've seen this with bowsaws cutting trees.
Try cutting very slowly.
Be careful; hand surgeons in the DC area charged one to four kilobucks per hour, in 1994 prices, and for this kind of money your hand works afterwards, sort of.
Old 06-25-2009, 07:53 PM   #44
Rewards Points: 780
Hmm....okay, I'll pay attention to how I'm pushing the handle down.
Old 06-25-2009, 08:13 PM   #45
Jay123's Avatar
cutting crown molding for cope cuts billyg Carpentry 6 05-04-2009 06:18 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
Special saw for clean cuts in drywall / plaster jamiedolan Drywall & Plaster 7 02-02-2009 06:05 PM
How to measure angles?!?! handbanana Carpentry 6 09-27-2007 09:31 PM
Bad tile cuts krush Flooring 5 06-18-2007 09:15 AM
