Saw Cuts Inaccurate Angles - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 06:08 PM   #16
Rewards Points: 336
*hic-up* I uh, um... *hic-up*....... It's just water for me all day.
Yep, I did check to make sure the blade is 90* to the fence when it's upright.
Sure I can post a pic of the piece of wood with it against the blade.
A meth lab, with kids in the house?
gma2rjc is offline   Reply With Quote
Old 06-25-2009, 06:11 PM   #17
Jay123's Avatar
I always make mine run to the store for beer and cigs when I'm mixing up a batch.
Jay123 is offline   Reply With Quote
Old 06-25-2009, 06:37 PM   #18
the Musigician
DangerMouse's Avatar
just be sure to remind them to put out any lit ones before they come back in the house.....
DM
Old 06-25-2009, 06:38 PM   #19
Jay123's Avatar
that's the rule
Old 06-25-2009, 06:49 PM   #20
2 fingered typer
woodnthings's Avatar
Lose the bevel...
Originally Posted by adpanko View Post
Did you check that your blade is 90* to the fence when it isn't tilted at all but is straight up at 0*? It seems like you confirmed your bevel is a true 45*, but in the bevel position, you're clearly not getting a 90* miter, which is messing up your compound cut. Lose the bevel, put the blade at 0* and measure if the blade is 90* to the fence.
Eliminate all variables:
Set the saw to 90 degrees using a framing square against the blade and fence, no bevel. Now make a cut on a piece of 6" wide plywood holding it firmly against the fence and flat on the table, and check it with a known 90 degree speed square or framing type square. It should be 90 degrees dead on if not, you got some justin' to do Lucy! Eliminate all variables. Now set the bevel to 45 degrees make a cut, flip one board and join them together to see if they "mate" bevel to bevel. If they don't fit your bevel angle is off. The blade needs to be sharp or you will get "creep" in your angles and that ain't good either!
Try this and report on what you get. OK? bill
woodnthings is offline   Reply With Quote
Old 06-25-2009, 06:52 PM   #21
Rewards Points: 336
I caught a toddler pulling a bunch of it out of his diaper bag one day. He was going to trade it for some gummy bears over at the neighbor's house.
Old 06-25-2009, 06:56 PM   #22
Jay123's Avatar
Old 06-25-2009, 07:06 PM   #23
Rewards Points: 336
Since I started this [roject, I've been to the store for a framing square, a speed-square and a protractor.
Every measurement I take measures at 45* or 90*. I didn't use the framing square though. I couldn't get it up against the blade and the fence or table at the same time, the safety gaurd was in the way.
I'll try fitting two pieces together inside the framing square.
Thanks for all the suggestions everyone.
Old 06-25-2009, 07:45 PM   #24
Rewards Points: 336
Here's the picture I meant to post earlier.
Old 06-25-2009, 07:53 PM   #25
Jay123's Avatar
are you sure that board is totally flat...not cupped?
Old 06-25-2009, 08:08 PM   #26
the Musigician
ooh! ooh! call on me! call on me! i know!
DM
Old 06-25-2009, 08:10 PM   #27
Jay123's Avatar
don't call on him....
Old 06-25-2009, 08:11 PM   #28
Jay123's Avatar
now I see the real problem...it's a black and decker saw
Old 06-25-2009, 08:14 PM   #29
the Musigician
ain't the saw.....
DM
Old 06-25-2009, 08:15 PM   #30
Jay123's Avatar
nobody called on you
cutting crown molding for cope cuts billyg Carpentry 6 05-04-2009 07:18 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 11:00 AM
Special saw for clean cuts in drywall / plaster jamiedolan Drywall & Plaster 7 02-02-2009 07:05 PM
How to measure angles?!?! handbanana Carpentry 6 09-27-2007 10:31 PM
Bad tile cuts krush Flooring 5 06-18-2007 10:15 AM
