Saw Cuts Inaccurate Angles - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 02:24 PM   #1
Rewards Points: 780
Saw cuts inaccurate angles
Does anyone have any suggestions as to why the boards I'm cutting are coming out crooked?
In the picture, the straight pencil lines on the two sides of the board are at perfect 90* angles to the top of the board. But look at how the cuts are bowed in the middle and wider on one side.
I checked the angle of the blade and it's tilted sideways at 45*. The saw has its own markings, but I also used a protractor to measure it.
I'm holding the board tight against the fence and the it isn't moving when the blade is going through it.
Saw cuts inaccurate angles-dsc09604.jpg-trim-re-sized.jpg   Saw cuts inaccurate angles-dsc09619.jpg-re-sized.jpg
gma2rjc is offline   Reply With Quote
Old 06-25-2009, 02:31 PM   #2
Jay123's Avatar
Is the board absolutely flat?
Jay123 is offline   Reply With Quote
Old 06-25-2009, 02:33 PM   #3
Experienced goon
Did you zero the fence to the blade when it is at center?
jpelzer is offline   Reply With Quote
Old 06-25-2009, 02:37 PM   #4
Rewards Points: 780
Yeah, the board is flat and when the blade is standing up straight it's set at 0. I used the protractor to check that too.
Old 06-25-2009, 02:40 PM   #5
DIY'r
ScottR's Avatar
Maybe your protractor is broken? j/k
Is there any play (wiggle) at the pivot point between the saw and the base?
Are the ends of that board cut straight, or are they back cut per the picture of your saw?
If they're mitered, maybe your saw is leaning forward (the front is lower than the back) relative to the base.
ScottR is offline   Reply With Quote
Old 06-25-2009, 02:56 PM   #6
Registered User
Rewards Points: 526
Use the allen wrench and the directions to reset everything. Go to the manufacturer's website for info. Be safe, G
Old 06-25-2009, 02:57 PM   #7
Rewards Points: 780
The bolt in the back of the saw is tight and there's no pivoting.
The edge of the board that rests against the fence is cut straight.
I'm not sure the saw is able to move forward. There is only one way to move it from side-to-side, and one bolt that loosens to allow the saw to tilt sideways.
Old 06-25-2009, 03:13 PM   #8
Jay123's Avatar
What time did you start drinking today?
Old 06-25-2009, 03:16 PM   #9
Remodeler
adpanko's Avatar
Rewards Points: 150
Did you check that your blade is 90* to the fence when it isn't tilted at all but is straight up at 0*? It seems like you confirmed your bevel is a true 45*, but in the bevel position, you're clearly not getting a 90* miter, which is messing up your compound cut. Lose the bevel, put the blade at 0* and measure if the blade is 90* to the fence.
adpanko is offline   Reply With Quote
Old 06-25-2009, 03:17 PM   #10
the Musigician
DangerMouse's Avatar
now that's not nice....
hmm... do you have a pic of the two together? that piece on the table?
can you take one?
DM
Old 06-25-2009, 03:18 PM   #11
Jay123's Avatar
just trying to cover all the bases
Old 06-25-2009, 03:22 PM   #12
the Musigician
read her other posts, she runs a daycare... i can just see the mommies coming to get their kids from the 'giggle lady' lol
DM
Old 06-25-2009, 03:24 PM   #13
Jay123's Avatar
you don't pay attention to the news enough...it happens
Old 06-25-2009, 03:43 PM   #14
the Musigician
sad but true....
they just busted a Foster Mom near/in Lansing Mi. for running a meth lab in her basement...
DM
Old 06-25-2009, 03:45 PM   #15
Jay123's Avatar
cutting crown molding for cope cuts billyg Carpentry 6 05-04-2009 06:18 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
Special saw for clean cuts in drywall / plaster jamiedolan Drywall & Plaster 7 02-02-2009 06:05 PM
How to measure angles?!?! handbanana Carpentry 6 09-27-2007 09:31 PM
Bad tile cuts krush Flooring 5 06-18-2007 09:15 AM
