Saw Blade Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-27-2013, 07:43 PM   #1
Rewards Points: 452
saw blade question
http://www.homedepot.com/p/202021690
does it look like this blade will make smooth cuts in plywood and crosscuts in 1x3 spruce/pine ?
I'm more concerned about getting smooth crosscuts in the pine.
pman6 is offline   Reply With Quote
Old 04-27-2013, 08:04 PM   #2
DIY staff
Rewards Points: 7,174
That is a cross cutting blade so you should be fine with that---I assume that will be in a hand held circular saw----if so---set the soul plate for a cut only 1/4" deeper than the wood to be cut--
Leaving the blade all the way down causes more tear out----
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
r0ckstarr (04-28-2013), Willie T (04-28-2013)
Old 04-27-2013, 08:16 PM   #3
Rewards Points: 450
It appears the hook angle may be about 10° and for smooth cross cutting I'd rather see that angle closer to 0° , but for that price I doubt you'll find a zero hook blade.
So go ahead and try it and if it doesn't work out you aren't out much money and can use it to cut old barn wood etc.
I just love spending other people's money.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
oh'mike (04-27-2013)
Old 04-27-2013, 09:08 PM   #4
Roofmaster
Rewards Points: 2,172
Do you have a miter saw? If not, now might be the time to buy one if you have a lot of 1 x 3 to cut. I have a Makita LS1013 Slide Compound, and I absolutely love it.
Old 04-27-2013, 09:37 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
that blade will work fine.. just dont rush your cuts through the material or it will splinter.
i use a 40 tooth freud diablo blade on my circ saw for breaking down sheets of good two side plywood all the time without issue.
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 04-28-2013, 02:46 AM   #6
Rewards Points: 452
thanks. the diablo is only $5 more, so i'll get that.
Old 04-28-2013, 10:58 AM   #7
Roofmaster
Buy a Swanson speed square while you are there. The small one. You will love it.
The Following User Says Thank You to jagans For This Useful Post:
pman6 (04-30-2013)
Old 04-28-2013, 02:48 PM   #8
Oso954's Avatar
Rewards Points: 444
Here is a video on some of the uses of a speed square.
http://www.youtube.com/watch?v=jh04y...yer_detailpage
Using it as a saw guide will give you much better cuts.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
pman6 (04-30-2013)
Old 04-28-2013, 09:26 PM   #9
Old School
Willie T's Avatar
You can hardly go wrong with a Diablo!
Willie T
Old 04-28-2013, 09:35 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Hey Willie, sure is good to see you back buddy.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-28-2013, 09:40 PM   #11
Old School
Willie T's Avatar
Hey! Had a stroke a little over a year ago, and the doctor said to stay away from forums. That's good advice for the frustrating Contractor Talk forum, but this one keeps drawing me back.
Willie T
The Following 5 Users Say Thank You to Willie T For This Useful Post:
BigJim (04-28-2013), frenchelectrican (04-28-2013), jomama45 (04-30-2013), oh'mike (04-28-2013), woodworkbykirk (04-28-2013)
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 09:11 PM
quick question on closet flanges corman Plumbing 3 11-18-2012 04:18 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 09:47 AM
