Which Saw Blade For Laminate Countertops? - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-04-2008, 09:48 AM   #1
Rewards Points: 77
Which saw blade for laminate countertops?
We'll be replacing our countertops with those pre-formed laminte countertops from HD. You know, these:
I'll have to cut a few pieces (straight cuts, not mitre). What kind of saw blade should I use to avoid chipping the surface? And am I correct that you cut from the underside?
Thanks.
Proulx06 is offline   Reply With Quote
Old 01-04-2008, 10:08 AM   #2
If you can cut from the underside you shouldnt have to worry about chipping out with a circular saw, but cut from the selfedge back to the backsplash to avoid chipping out the self edge.
RTRCon is offline   Reply With Quote
Old 01-04-2008, 10:30 AM   #3
Oldguy
Rehabber's Avatar
Laminates are hard on blades, I just bite the bullet and use a Frued 40 tooth
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-04-2008, 12:34 PM   #4
Rewards Points: 77
Most instructions say to use tape on the finished side to prevent chipping, so it seems it does happen. The Frued brand...can I get that at the big box stores? Are there different models of 40-tooth blades? I am just totally ignorant in this area and don't want to ruin a piece of countertop because I had the wrong blade. Thanks guys.
Old 01-04-2008, 07:30 PM   #5
The Irwin Marathon blades work pretty well. When I cut countertops I runt he saw backwards. It is not the safest practice, so I would recommend cutting from the bottom side if you aren't EXTREMELY comfortable with a circular saw.
send_it_all is offline   Reply With Quote
Old 01-15-2008, 09:45 PM   #6
Cabinet GURU
if your buying it in Home Depot they should cut it for you ...I know my local one does.
michael.skofield is offline   Reply With Quote
Granite Countertops and Restaining kennykenny Remodeling 64 05-02-2009 12:15 AM
What saw blade do you use to cut soffits? Malcolm Roofing/Siding 3 06-14-2007 12:48 PM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 02:00 PM
Free Recip saw blade Brik Building & Construction 2 01-16-2007 05:40 PM
Circular Saw Blade Recommendation allen1466 Tools 7 06-07-2006 07:58 AM
