Sanding A Slope/bevel In Wood? - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-25-2012, 03:56 PM   #1
Rewards Points: 260
Sanding a slope/bevel in wood?
Hi all. So I'm building some new window cases for my garage windows and the bottom piece of the case needs to be sloped/beveled for water runoff. Does anyone have any suggestions as to how I exactly I could do this? Thanks.
Jesse
jpearson311 is offline   Reply With Quote
Old 05-25-2012, 04:12 PM   #2
Civil Engineer
Rewards Points: 4,790
If you can take the bottom off to do the work, there are several options. You could bevel the bottom with a table saw, router, or jointer. You could bevel it by hand using a plane.
If you cannot take the bottom piece off, you could sand it using a belt sander for the middle and a pad sander towards the edges. Or you could use a hand plane. Or you could rout the middle part, then finish the ends using a hand plane or pad sander. If you had an orbital tool like a feinmaster, you could use that for the whole thing.
Daniel Holzman is online now   Reply With Quote
Old 05-25-2012, 04:24 PM   #3
Rewards Points: 260
Ok. I can take the bottom off because the cases aren't built yet. I'm having the sashes built by a wood shop and I'm building the cases. I do have an orbital sander and I also have a craftsman multi tool. Similar to a feinmaster I believe. I still don't understand how to slope it in a uniform manner though.
Old 05-25-2012, 06:19 PM   #4
Civil Engineer
In order to slope in a uniform manner, you need to run the piece along a fence. This is easily done if you have a table saw, you just set the blade angle to whatever you need, set the fence to the appropriate width, and run the wood along the fence. This is by far the easiest way I can think of to create a sloped edge on a straight piece of wood.
You can do the same thing with a circular saw by setting the fence, adjusting the bevel on the blade, and running the saw along the fence. This does not give as good a result as the table saw, but it can work.
Using an orbital sander is tough, since there is no way to set a fence, you have to do the work by eye, which is difficult. Recommend you find a table saw to use.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
user1007 (05-25-2012), Willie T (05-26-2012)
Old 05-25-2012, 07:07 PM   #5
Rewards Points: 13,750
You do know you can by these premade in vinyl so there's not more rotting or wood right?
Old 05-25-2012, 09:35 PM   #6
Too Short? Cut it Again!
Table saw will be the easiest and once you set the fence and blade angle all should be consistent. A hand plane would be my second choice if you need to shape them individually for some reason. Your multi-tool and sander are not the tools for this.
Of course to do it right you will need one of these limited edition planes. Each is signed and go for $3,222. I still have my Dad's and Grandfather's or I most certainly would buy a couple.
The Following User Says Thank You to user1007 For This Useful Post:
mae-ling (05-25-2012)
Old 05-26-2012, 07:40 AM   #7
Civil Engineer
I used one of those planes to shave down the frame on my Mona Lisa original edition. It did a great job, except I slipped a couple of times and cut up the canvas. Guess I will have to get a replacement, anyone know where DaVinci is living these days?
The Following User Says Thank You to Daniel Holzman For This Useful Post:
VIPlumber (05-26-2012)
Old 05-26-2012, 09:01 AM   #8
My art gallery clients used to hate it when I leaned ladders against paintings and accidentally put holes in canvas paintings. Don't worry about Mona. When you really look at her she was not all that hot anyhow. A little duck tape on the back and some touch up with 2.5 inch angled sash brush and only you will notice.
If you must get another authentic original. Oscar DaVinci runs a shop out of Brooklyn. You leave him a photo of any piece of art. He sends it off to Taiwan and two weeks later you get your masterpiece by air freight.
Old 05-26-2012, 11:46 AM   #9
In a little over my head
Rewards Points: 706
How deep/wide is the sloped surface? If the window is near flush to the outside wall, and the sloped surface is less than an inch or so, a circular saw will do fine. Just build ur use a guide. If we're talking about sloping a stool, several inches deep, things get more complicated.
ratherbefishing is offline   Reply With Quote
Old 05-26-2012, 12:12 PM   #10
Rewards Points: 260
Thanks Joe. Yes, I know, but I live in a historic district and you cannot use vinyl, on anything for that matter. Thanks!
Jesse
Old 05-26-2012, 12:43 PM   #11
Rewards Points: 636
i am assuming exterior. what i do is cut a 15 degree on front and back and to the width desired so it makes a parallelogram.then i put a 3/16 round nose bit in my router and put a drip groove on bottom off sill 3/16 deep and 1/4 to 1/2 in from front edge. i then cut sill and head to sizes desired, cut my legs to length and width needed with bottom being beveled to 15 degrees and drill for pocket screws in back of legs. assemble all together so back of legs, sill,and header are flush and pocket screw together. then after window is installed and rubber flashed accordingly the trim is ready to be nailed and sealed in to place.
wood material used i usually use are cedar, mahogany or pine
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
Help with adding custom color to wood filler 4thDimension Carpentry 5 10-14-2011 01:46 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
