Sanding Dust As Hole Filler? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 06:29 AM   #1
Sanding dust as hole filler?
Is it possible to use sanding dust as hole filler? I'm wondering if there's some sort of compound I can mix with it to make it a paste and fill in nail holes?
Thanks in advance!
Jeffreybomb is offline   Reply With Quote
Old 11-17-2011, 06:54 AM   #2
It is used all the itme, matches the wood best. Mix some saw or sanding dust with any wood glue(I use TitebondII), pack the hole to overflowing, and let it dry completely. Sand it offf and you are done.
The Following User Says Thank You to Just Bill For This Useful Post:
DangerMouse (11-17-2011)
Old 11-17-2011, 07:30 AM   #3
Rewards Points: 120
I keep a couple of peanut butter jars of sawdust with my woodworking tools, just for that purpose. As Bill said, it works great.
Old 11-17-2011, 10:28 AM   #4
It will fill the hole and match the bare wood, but I can't see it matching stain and it's a moot point if it's being painted
mrgins is offline   Reply With Quote
Old 11-17-2011, 04:10 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
the saw dust and glue trick has been in use for years, predating actual wood fillers.
the problem with using actual wood fillers is if the wood isnt finished yet the oil from the filler can stain the wood leaving a blotchy finish. when i fill nail holes i put my first coat of poly on first then fill the holes so i dont have to worry about the blotch issue
woodworkbykirk is offline   Reply With Quote
Old 11-17-2011, 05:43 PM   #6
Unfortunately, most carpenters have to leave the filling to the finishers who, hopefully, know how to fill, or even to fill, period!
Old 11-17-2011, 06:51 PM   #7
unfortunately most carpenters aren't actually carpenters, their just guys working in the trade
they havent received any formal training where this sorta thing is taught
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 02:52 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 09:57 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 10:04 PM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 10:06 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
