Salt Box Storage Shed - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-07-2010, 07:15 AM   #1
retired guy
igneous's Avatar
Rewards Points: 135
salt box storage shed
I intend to build an 8x12 salt box storage shed with 8' front wall and 7'rear wall. My question is how do I determine where to make the ridge? Also, how do I determine the height? I have basic construction skills, but lack the vision to do it right the first time. Igneous
igneous is offline   Reply With Quote
Old 03-07-2010, 07:23 AM   #2
DIY staff
Rewards Points: 7,174
What wall is the face---the 8 or the 12?
Old 03-07-2010, 07:24 AM   #3
Civil Engineer
Rewards Points: 4,680
Please clarify the post. Your front wall is 8 feet, and your rear wall is 7 feet. Is there some reason you want to build an out of square shed?
Old 03-07-2010, 07:50 AM   #4
retired guy
igneous's Avatar
Rewards Points: 135
The front wall 12'long will be 8'tall and the rear wall 12'long will be 7' tall. The side walls 8'long will be stick-built to accomodate the rafter angle. At least that's my plan. So you are looking at the front of the shed(door and window).I could also build the shed 8'tall on all four sides and install a ridgeboard and attach the rafters to it. My question has to do with the angle and height of the ridge. It is my understanding that the ridge is not centered above the building, but forward of center creating the saltbox look.
Old 03-07-2010, 08:24 AM   #5
DIY staff
Salt box style storage shed plans.I googled saltbox shed plans--lots of ideas there--
Old 03-07-2010, 11:17 AM   #6
Framing Contractor
What is the pitch?
What size rafters and ridge?
What is the overhang?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-07-2010, 12:47 PM   #7
retired guy
igneous's Avatar
Rewards Points: 135
Thanks all. The web page definitely helped me with a plan to form the angle of the roof and side wall framing.
Old 10-05-2011, 04:43 PM   #8
Saltbox roof truss
When I design salt box sheds I use a 12/12 pitch on the front roof and a 5/12 on the rear roof. You will probably have about 4/12 if you make the rear wall 12" lower than the front wall. I would keep the front roof pitch at 12/12 and let the rear wall fall where it may. Another rule of thumb is to have the ridge about 1/3 back from the front wall. But that does not always work. I have several salt box shed plans at http://www.icreatables.com/sheds/shed-plans.html I attached a drawing of a common salt box shed roof section. I hope it helps.
icreate is offline   Reply With Quote
Base for Lifetime (plastic) storage shed proofer Building & Construction 13 07-03-2015 05:09 PM
building a storage shed blk90s13 Landscaping & Lawn Care 17 03-22-2011 10:42 PM
Preparing site for a storage shed DIY4EVER Landscaping & Lawn Care 3 01-01-2009 09:51 PM
Base for Storage Shed cbsrugby Building & Construction 6 05-08-2008 01:41 PM
Storage Loft in Metal Shed Traveller Building & Construction 6 09-30-2007 03:08 PM
