Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-15-2011, 06:29 PM   #1
sagging door sill
Both my back door and garden doors have sagging sills, both corners bend down. The back door sticks a bit, but with the garden doors only one will open and that's with difficulty. I'm getting rather confusing advice on what the problem may be. I've checked that the doors are level and the hinges are fine.
Could this be a problem with the header, or could it just be the sill? Do I really have to remove all the siding from that part of the house to address the issue!
gheudi is offline   Reply With Quote
Old 08-15-2011, 07:16 PM   #2
sagging door sill
I think a picture is needed to help with understanding the issues you have. Do you mean the thresholds are sagging? What are they made of? What are thresholds sitting on top of? When I hear sill I think of the framing member sitting on the foundation but understand sill is also used for door thresholds. Just want to make sure we're talking about the same thing.
bob22 is offline   Reply With Quote
Old 08-15-2011, 07:31 PM   #3
sagging door sill
You mention both the top and bottom of the door as the problem. An unlikely situation. As Bob says, post a photo.
Ron
B. Franklin 1759
Old 08-16-2011, 01:31 AM   #4
Framer
sagging door sill
joeyr is offline   Reply With Quote
Old 08-18-2011, 12:18 AM   #5
sagging door sill
If both corners of your threshold are bending down it could be because the sill underneath is rotted and because you may a missing or improperly supported header.
hayewe farm is offline   Reply With Quote
Fixing sagging floors in a 123 yr old house. meccadon Building & Construction 5 04-13-2011 10:58 AM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 01:15 PM
Sagging 2 x 6 rafters on a 4:12 pitch Kerins Woodwork Roofing 7 11-29-2009 07:10 PM
Sagging Roof nayak143 Roofing 15 06-12-2009 02:03 PM
My roof is sagging - Correct Course of Correct Repair? young-jennifer Building & Construction 5 12-15-2008 08:59 PM
