Saber Saw Limitations? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-20-2008, 02:07 PM   #1
Rewards Points: 682
saber saw limitations?
Can a saber saw cut a 1-3/4 thick door slab well? Or is that too thick for that tool? What is the heaviest work a saber saw can do well?
Also does anyone have any favorite saber saw brands? Usually I just buy dewalt for everything.
darsunt is offline   Reply With Quote
Old 02-20-2008, 03:59 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Bosch make a very good one It will cut a door but may leave a rough finish I would use a cirular saw
Kingfisher is offline   Reply With Quote
Old 02-20-2008, 09:00 PM   #3
remodeling pro
Circular saw with a straight edge is best. But you could cut it with a good sabre saw like the Bosch. This saw, teamed up with their quality blades give you a whole new outlook on using sabre saws. If you do not have a saw that will acept the top notch Bosch or Hilti blades, don't waste time.
troubleseeker is offline   Reply With Quote
Old 02-21-2008, 12:50 AM   #4
Custom Deck Builder
BuiltByMAC's Avatar
Limitations? Not many... I cut curves in 4x material with my Bosch jigsaw and a 6" blade. Go very slow as the blade will have a tendency to wander in thicker material.
Good quality blades are half the battle - you'll want a jigsaw that can accept T-shank blades, they look like this:
Teeth that are angled upward will produce a rougher finished cut than downward-facing teeth...
Favorite brand - easy, Bosch.
Good luck with your project,
Mac
BuiltByMAC is offline   Reply With Quote
Old 02-21-2008, 09:15 AM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
That Bosch is the best, no question. Its night and day compared to every other jigsaw I have used. The best tool for your job is a circular saw. That said, if I only had this bosch jigsaw and had to cut a door bottom I would not hesitate. I would never attempt it with any other jigsaw.
I plan on doing a head to head tool test with this bosch and some other jigsaw in a future podcast. Not sure when yet. Middle spring likely. If anyone has a jigsaw they would like to donate for the test let me know!
Brik is offline   Reply With Quote
saber saw or cut-out tool amakarevic Electrical 6 06-11-2007 09:54 AM
