Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-04-2013, 09:32 AM   #1
S-Turn Railing
I am installing a railing that has an S-turn where it transitions from open risers to closed risers at the cieling. I know that usually the balusters leave the railing at the s-turn and then run from the tread to the cieling. Has anyone ever seen a stair where the balusters follow the s-trun and attatch to the railing all the way up to the top of the stairs?
Monty1123 is offline   Reply With Quote
Old 02-04-2013, 09:10 PM   #2
Stair builder
S-Turn Railing
Run the rail into the ceiling and put a wall mounted rail on the other wall.
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
BigJim (02-04-2013)
Old 02-05-2013, 08:35 AM   #3
S-Turn Railing
Thanks Keith. That is defenitly the best solution but unfortunatly I have a small window on the oposite wall. The wall mounted railing would cut right across the window for the last three steps.
Tags
railing, s-turn
PVC Stair railing DIY_user Building & Construction 1 10-26-2009 08:59 AM
How to attach oak railing between two walls jagermeister Building & Construction 4 08-26-2009 02:12 PM
Rust Stains from Railing on Concrete Walk stubits Building & Construction 2 06-05-2009 06:20 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
