-   -   S-Turn Railing (http://www.diychatroom.com/f14/s-turn-railing-170972/)
Monty1123 02-04-2013 09:32 AM
S-Turn Railing
1 Attachment(s)
I am installing a railing that has an S-turn where it transitions from open risers to closed risers at the cieling. I know that usually the balusters leave the railing at the s-turn and then run from the tread to the cieling. Has anyone ever seen a stair where the balusters follow the s-trun and attatch to the railing all the way up to the top of the stairs?
Keith Mathewson 02-04-2013 09:10 PM
Run the rail into the ceiling and put a wall mounted rail on the other wall.
Monty1123 02-05-2013 08:35 AM
Thanks Keith. That is defenitly the best solution but unfortunatly I have a small window on the oposite wall. The wall mounted railing would cut right across the window for the last three steps.
