Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-06-2009, 05:34 AM   #1
Lightbulb
Rubber Sanding Blocks
Hello,
I'm writing to enquire if there is any interest in a new design of rubber sanding block that would include:
Tack (nail)-free holding of sand paper that ensures a constant snug fit
Improved ergonomics for better grip and modulated pressure application to work
I have a prototype product and trying to get feedback to gauge dissatisfaction for existing sanding blocks and enthusiasm for new designs.
Thank you,
Pirahna
Pirahna is offline   Reply With Quote
Old 12-06-2009, 05:50 AM   #2
sdsester's Avatar
I guess it sounds interesting. I don't use traditional sanding blocks that much since the integrated 3M abrasive sponge things are so cheap and my power contour sanders can be shaped to just about anything.
sdsester is offline   Reply With Quote
Old 12-06-2009, 06:33 AM   #3
Tool Geek
PaliBob's Avatar
Here is a new design from Festool that comes in a cool green box.
http://www.cpofestool.com/products/m...=frooglem0107#
The sanding blocks that use 3x21 sanding belts are handy for coarse to medium sanding by switching grit size belts. The simplest ones are just made from a block of scrap wood but commercial versions have more edge profiles.
http://woodworker.com/fullpres.asp?P...3&LARGEVIEW=ON
There are some really cheap sanding blocks that work OK
http://search.harborfreight.com/cpis...ocks&Submit=Go
And then sponge sanding blocks are getting cheaper
http://search.harborfreight.com/cpis...nges&Submit=Go
Good luck on your endeavor. We need more made in the USA products.
& Stay Safe
.....Bob Lavery
Tags
blocks, finishing, rubber, sanding
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 09:15 AM
rubber coating for paved backyard hellomoto Landscaping & Lawn Care 3 10-18-2009 11:09 AM
cinder blocks under tub? Leoskee Building & Construction 8 09-03-2009 05:52 PM
Help with repairing a flat rubber garage roof Toasty Roofing 2 07-01-2008 09:43 AM
Rubber roof prices tgf40 Roofing 4 05-27-2008 02:02 PM
